Wasteblocks/Glue/Eccentric-MultiAxis Turning
Devon Palmer
>Greetings all,
This summer, I saw Jean-François Escoulen demo his new Multi-axis AND eccentric Chuck. Needless to say, its the first thing on my list for my Birthday/Christmas Gift to myself.
Since it primarily uses a face plate, I'll used waste blocks often. I've used CA Glue in the past for goblets, etc,; little stuff that won't have a lot of shock/impact. But, I've heard conflicting things from other turners and on the net about CA glue for waste blocks.
Are there better ways/means of attaching waste blocks? titebond, epoxy?
Re: Wasteblocks/Glue/Eccentric-MultiAxis Turning
>I don't think you willlhave a problem with CA espcially if you Don't use the accelorator. However yellow glue, gorilla glue and epoxy will all work well. My choice if I was worried about impact would be 5 minute epoxy. It cures quickly and is strong enough. John
Wally Dickerman in Arizona
>I've been using waste blocks for many years, and students regularly use them in my classes with great success. When using a waste block there are several "musts" to be observed. The surfaces of the blank and the waste block must be true and flat as in any other glue joint. I use medium CA glue, but yellow glue or other glues can be used. I apply a heavy coat to both surfaces. After applying a light spritz of accelerator, I apply the waste block to the blank. No clamp, just firm hand pressure for a few moments. The piece can be mounted on the lathe immediately. I've found that if a waste block glue joint fails, it's usually because not enough glue was used. Expect some squeeze-out. Don't worry about side impact. The joint will be a strong one.
I use alder for waste blocks because it almost never warps, giving me a flat surface for the glue joint. Most any soft wood will work. I suggest that you never use plywood, as it may separate.
Wally
Norm Smith in Nova Scotia
>Hi Devon,
Who sells this chuck and what are the pros and cons?
Norm
Devon Palmer
>Craft Supply sells it, but, I haven't been able to find it on their website or Catalog (haven't gotten a catalog in a while tho), unfortunately, its not even listed on Jean's site. I like it becuase its not only multi-axis, like his original, but, its eccentric as well and looks like its a good bit beefier. If I get one, I'll post a pic of it.
- Devo
