Wecheer Power Carving
Ed Moore
>Has anyone had any experience with the Wecheer Power Carving unit?
And are there any good deals on bits and gouges for power carving?
Thanks in advance,
Ed
Re: Wecheer Power Carving
Jennifer@Indy.USA
>Ed I bought one and so far I am very plesed with it. It has plenty of power and seems to be a very well put together piece of equipment. I am curious to hear from somebody as to how "warm" the handpiece should get? Mine gets a bit warm. Not to the point where I can't hold onto it...but warmer than I think it probably should? Could the cable inside be rubbing incorrectly in the handpiece? Any ideas or comments?
Thanks,
Jennifer
Mark Kauder, Phenix City, AL
>Are you guys talking about the rotary carver or the reciprecating one?
I have the reciprecating one that attaches to a Dremel and love it, but I use it mostl for short periods.
Send a note to Mike Schwing, he had some trouble with a couple of them, but I do not know if it was Rotory or Recip.
Mark
Ed Moore
>Actually, I was considering getting the rotary carver and saw that you can get the reciprocating carver for only about $60 more. I'm thinking about doing some damage to some peppermills I intend to make in a week or two.
Ed
Don Evans
>Jen:
I don't have that brand, but any flex shaft will get warm and also hot especially the more you OVER bend it. Remember there is a spring type center that is spinning inside the sheath and the more you bend it the more it rubs inside as it is turning.
This is the reason I don't like stationary holders for the motor portion. If you suspend it with two pullies, one over your head and a foot or so to your right (if right handed) and the other pulley near the wall with a counter weight on the end of the line holding it you can control easily the down and up of the motor and keep the shaft reasonably straight with only slight bending.
Works for me. Keep one over the lathe and one over the workbench this way. For counter weight use metal pipe from hardware store, also one end cap that screws on. Drill hole in center of end cap and run line through it and tie a dowel to it or big knot in end of line. I found for a dremel it takes a piece of pipe about the same physical dimensions as the dremel itself 1.5 x 6" or so.
Don't forget to lubricate inside of shaft with grease often.
Don
Jennifer@Indy.USA
>Don thanks. I've been trying different ways to hang the motor and have yet to figure out a comfortable one. I'm not crystal clear on your description....would love to see a picture of your set up. It sounds like a great idea. I have mine hanging on the hook that came with it, moutned on a board that I then hold in my bench vice. The only problem with that is that it's on my left side while sitting at the bench and I'm right handed.
Jen
Bob Elliott
>Yeah, Don,
How about some pictures?
>Don Sounds like a good tip for American Woodturner. Send me a description and photo and I will try to get it in. Plus I'd like to see the photo as well. I'm in the process of rigging up a carving work bench and want to add all possible accessories.
Me too!
Jennifer@Indy.USA
>John, I would love to have a dedicated area for "post turning work" such as burning,coloring, carving etc. My bench houses my chop saw and it gets really cumbersome to move things on and off the bench. I have a vision in my mind but I would love to see what other people's carving areas look like.
Jen
Don Evans
>Gosh guys its really simple and I will provide pictures etc when I can. There is just one big problem in the mean time. I just moved and my shop is in pieces so I'm a frustrated turner at the moment. The stakes are in the ground for the new shop, could send pictures of those but wouldn't help much.
I'll see if I can reinstall it in the garage over the lathe or something temporarily for photos, is there anyone I could send them to that could take all the piled up stuff in the background out?
Don
Jennifer@Indy.USA
>Don,
Please don't go to any extremes to supply us with a picture. Sounds like you have your hands full! If you have a camera....perhaps a sketch and then take a pic of the sketch....just someday when you're completely bored and nothing better to do :)
Jen
