3x3 wood source
gary clarke
>I want to make some pepper mills and I need 3x3 wood and am having trouble finding a good source for the blanks. any ideas? any help appreciated.
3x3 wood source
gary clarke
Re: 3x3 wood source
Sean Troy
>Bat blanks make good stock for pepper mills. Our local Woodcraft carries them.
Re: 3x3 wood source
Gary Evans Tallassee, TN
>Gary,
I have some cherry, hickory, white oak and Central American Mahogany that is in 3"x3"x12" or slightly larger, dry blanks. I can cut green 3"x3" blanks from Holly (slightly spalted,) Eastern Red Cedar, Cherry crotch, Hackberry (spalted and not,) Oak burl, Maple crotch, Bird-peck hickory and others. Prices from $5 to $15 depending on species and figure. 10% Discount for $100 order.
I would be shipping from Knoxville, TN 37920
Let me know if I can help you out. I've almost got things set-up to where I can take credit cards. Hopefully by the end of this week.
Gary Evans
Talasi Hardwoods
Re: 3x3 wood source
>If you are looking for exotics, you might also want to try West Penn Hardwoods. They are listed in WoodFinder. They're probably a lot more expensive per blank than Gary, but you'll get better selection, and probably better prices than whatever your local Woodcraft might have in stock.
If you are willing and able to do some of the sizing yourself, again try WoodFinder, and look for dealers in 12/4 hardwood stock. This is often used for things like table legs and bed posts. You will have to crosscut it to length, even using a handsaw, yourself. You will also have to inquire about the widths, because they are random. When you get it, saw it to 3" width on your bandsaw. You'll find lots of uses for the offcuts. Also, they may be willing to sell "shorts" (too short for table legs) for less per board foot than their quoted prices. You will want to ask them about expected wastage on the ends due to end checks. But, if you tell them 3x3, they will immediately spot you as a turner, and the price goes up, because of the extra processing they have to do, and because they know some turners are used to paying high prices (because other turners are used to paying nothing at all). :^)
Re: 3x3 wood source
>Atlanta Wood products carries stock sized for legs. It's about 3 1/2 square I think. They also have mahagony in those sizes.
Re: 3x3 wood source
kenny in indep
>What woods would or might be toxic for salt and pepper mills? Thanks for your time.
Re: 3x3 wood source
Bruce McElhaney Spring Lake, MI
>I've purchased Table Leg Turning Blanks for my Peppermills from Adams Wood Products in Tennessee. They carry, Walnut, Maple, Oak, Cherry, Mahogany and Curly Maple. They are of fine quality and reasonably priced. Exotics are expensive, and some are toxic to work with.
Re: 3x3 wood toxicity?
>Kenny, I've made Peppermills out of many different woods and never worried much about their food toxicity, as finished wood is only as toxic as its finish. Plus, I always use shellac as a sealer on the interior. However, Spalted woods may require extra attention to make sure they're well sealed.
kenny in Indep
>Thanks for your help, I will be using shellac sealer on the inside.
