Getting Started in Woodburning
Mark Trenier
>Molly Winton's cedar vessel on the cover of Packard Woodworks catalog sure got me to thinking about using a woodburner to start adding some decoration to my bowls. But where do I start? Can I purchase a nice started set for about $100 and what tips do I start with? I also do calligraphy with pen and was wondering if I could take that skill and apply it to my bowls.
Thanks for all your advice.
Mark Trenier
Re: Getting Started in Woodburning
>Mark You can indeed do calligraphy. It will require smooth grain woods to do it. Woods with a lot of difference between the summer and winter wood burn unevenly and requires a lot of skill to get a smooth line. Smooth woods burn more evenly. Get a good quality burner. To do good calligraphy you would need a lot of control of the heat. I bought the Colwood detailer and it's pretty good and one of the cheaper units on the market but it can be difficult to control a burn that is less than black. Say you want to write using a dark tan line. It's tough to control it with this pen and burner combination. Since I don't have any experience with the better burners I can't say for sure if they will do this but when you look at the better pyrography sites they apparently have a lot more control(and skill) than I do.
The Optima burner seems to get a lot of praise.
Molly Winton
>Thanks Mark! As John says, you can do caligraphy. When I was recently checking out various pens some of them were advertised as being specifically good for caligraphy. There was a pretty long thread just recently about the pros and cons of various burning units. The three most discussed included the Optima, DetailMaster, and Razertip. The Optima is getting very good reviews by this group, but I've not tried it out (although I'm thinking about it for a back up burner). I'm not sure the price for it, but you can get the Razertip for about $99., and the DetailMaster Sabre for about $170. Pens can be extra and run anywhere from $16. to $20. each.
John gives good advice about writing on smooth grained wood. I highly recommend when you first get a machine to just play with it A LOT on scrap woods to see what you can do with various temperatures and tips. When I first start burning on a new wood I always try scrap first because you never know how the heat will react with unfamiliar wood (regarding temp., pressure, etc.).
The pens I most frequently use include a skew for fine lines, and a writing tip (more of a blunt end) for relief burning, and stippling. Obviously you can use them for many other effects as well, but they tend to be the most popular pens to start. Have fun!
Ed Karch in No.VA
>Molly
do you finish before burning or after or a bit of each?
Molly Winton
>Definitely after Ed. I had to go back and repair one of my pieces after I had applied the Danish Oil. YUCK! on many fronts. The fumes were awful, and the heat caused the oil to bubble up and make a gooey mess. The primary concern I had were the fumes, but I took care of that by using a respirator. Clean up was a pain, but I think I got it cleaned well...finally.
Don Evans
>Mark:
In the very beginning of my first trying pyro I went through some of the less expensive burners and returned them almost immediately. I learned that the cut over point for a good burner is the 100 watt mark. I ended up with the Detail Master Sabre and still have it but since then a new guy has come on the market called (I think) a "Burn Master" its red and you can see by the cabinet and exposed screw heads they used a regular electronics hobby box to keep cost down. But who cares about the astetics (sp) of it right, I don't.
If I were getting another one it would be the burn master which has 130 watts power and it will take anyone elses tips you want to use. I'd also be tempted to try a razortip handpiece. I know Detail Master has a calligraphy tip but be sure and get a regular writing tip also it will do most any burning I want to do except when I make my own tip for larger area burns in a special pattern.
Woodcraft carries the Detail Master and Burnmaster can be seen for less that $100.00 but check around as their price varies depending on dealer.
Don
