Re: Approximate drying time
Gary Evans Tallassee, TN
>Hi Doug,
I'm assuming that Seattle has a fairly high relative humidity from season to season. Unless you are storing these in a heated and cooled room, I would suggest taking them out of the paper bags. If the roughed-out bowls are Anchorsealed completely and the RH is high, they'll dry a lot quicker without them. If the room is conditioned, then I'd leave the bags on.
If the storage area is unheated, I'd say that the 10 month estimate is a good one for air-drying, particularly since we are headed into fall and winter when the rate of drying is much lower. But, if you get a postal scale, you may find that some of them are ready much sooner than 10 months.
If the room is heated, then you really need to be careful of how rapidly the bowls dry. Heated spaces have RH numbers that are quite low and the drying rate will increase accordingly. Here again a scale would be handy to calculate the drying rate from day to day. There are several charts available that show the maximum drying rate per day for a particular species.
Gary
