Mark Mandell
CapeMayMike
>Mark,
I've noticed posts from you in the past re: Vacuum chucking. I assume that you have a filter on your system. That's one component that I haven't been able to run down locally, where did you get yours?
Thanks,
Mike
Mark Mandell
CapeMayMike
>Mark,
Thanks,
Mike
Re: Vacuum Filter *LINK*
>Mike,
Got mine from Surplus Center, but unfortunately the last time I looked they hadn't gotten any more in. You can, however, use an in-line air filter. Just remember to clean and/or replace it from time to time. Follow the link for one that should work
Surplus - Filter
Re: Mark Mandell
Roger T
>Mike,
Try here,
http://www.joewoodworker.com/catalog/product_info.php?cPath=36&products_id=1100
I just got one from here for my vac chuck system. They have a $50 minimum order i believe, but the product got here quickly. I cant remember but I think they hit you another couple of bucks for less than 50 order.
Roger
Thanks guys!
CapeMayMike
Another ?
CapeMayMike
>Mark,
Have you used your system with a bag for veneer work? I have the Gast from Surplus and see no reason why it couldn't perform double duty.
Mike
Re: Vaneer
>Mike,
The pump with work just fine, however you will need a vacuum reservoir and possibly an actuator switch. People make the reservoirs out of sections of 4" Sched. 40 PVC, old 20lb. propane tanks, old compressor tanks, or anything that will seal and take the cumulative atmosphere pressure. The tank provides a stability in the vacuum, much like an air storage on a compressor that smooths out the pump pulses and gives the pump a rest. That's also where the actuator comes in. You set it for say 20" Hg. and the pump won't have to run continuously for the 12-15 hours needed for the glue to set properly. If you follow Roger's link and then poke around on the joe-woodworker site, you'll find a bunch of stuff on the question as well as plans for a set up and examples of what others have done.
Mark
Re: vEneer :-]
