OT: Bending High Speed Steel
Bob Moffett
Bob Moffett
>I want to make some hollowing tools for making ornaments out of 1/4" high speed steel stock. What is the best way to bend them and keep the hardness of the HHS? I will be bending one 80 degrees and another about 45 degrees.
Thanks,
Bob M.
Re: OT: Bending High Speed Steel
>Bob I assume you are using solid pieces of HSS. You can simply heat it red hot at the point you want it to bend and bend it. It won't hurt the hardness. I make my tools by silver solering a HSS cutting tool to the tip. You can get HSS cutting bits for as little as .75 cents. I cut them in half and make 2 cutters out of each.
Ed Karch in No.VA
>I bent my Crown Ellsworth 1/2" gouge with one good solid catch on a big bowl.
JimQ
>That's not the right way!
JimQ
Another way
Phil Joines Krum, Texas
>Long arm Allen wrenches. Just cut the end back and gring to shape.
The one in the link is 1/4" x 12".
Lost the link *LINK*
>http://www.use-enco.com/CGI/INSRIT?PMAKA=240-1803&PMPXNO=4831277&PARTPG=INLMK32
WOODNUT358
>The allen wrenches work good,and so do old screw drivers.Just turn some small handles and epoxy them in.As far as bending the screw drivers,that's easily done with a vise.
>If you use old screwdrivers and allen wrenches you will probably need to reharden them if you want them to hold an edge. It's not absolutely necessary but I find they hold an edge a lot longer. I have several allen wrench, screwdriver, and file tools that I made for special applications.
Bob Moffett
Bob Moffett
>So, How do you reharden them?
Re: 'Splain this to me
Frederick Nelson
>How is 1/4 inch "Metric"? 6.35 millimeters I'd understand . . .
FNelson
>Bob It's simple. Heat it red hot. They say Cherry red. To find out for sure if you reach the proper temperature simply hold a magnet up to the red hot steel. If it is non magnetic you are at the proper temperature. Quench it in oil. Motor oil is fine. Do this outside, it smells and could catch fire. Use a metal container and just put a lid on it if it does catch fire.
Now it's too hard and you have to soften it. The simplest way is to put it in the oven and heat it to 450 degrees for 30 minutes per 1/4" of thickness. Let it cool down and it's ready.
If you'd rather do it the blacksmith way sand or polish the metal so it's reasonably shiny. Now heat the tool about an inch from the tip. It will start turning yellow then blue. You want the light straw colored yellow to creep toward the tip. When it gets there quench it in the oil. Now it's ready.
This is very aproximate because you don't really know what kind of metal the screwdriver or allen wrench actually is made of but in my experience it dies make the metal harder and holds an edge better. Not anywhere near as good as High Speed Steel but good enough to use.
Bob Moffett
Bob Moffett
>Thanks for the help everyone.
Bob M.
