Woodworm Screw
Carole in VA
>I am assuming that this method of mounting should not be used in end grain. Is that a good assumption?
Woodworm Screw
Carole in VA
Re: Woodworm Screw - not for endgrain
Rick Allen
>Hi Carol
A screw chuck isn't a good choice for endgrain mounting. That being said, screw chucks are often used for small endgrain turnings such as bottle stoppers or drawer pulls.
Generaly a screw chuck is most efective on face turnings.
Good Luck
Richard
Lan Brady
>Carole,
You will not beleive how good it holds, until you try it.
Lan
Re: Woodworm Screw
Curt Fuller
>I've had good luck using a wormwood screw on end grain so long as the other end is supported with the tailstock, and then only to turn a tenon that can be mounted in the chuck jaws. But I've found the wormwood screw to hold very well in side grain without the support of the tailstock.
