A55 Smoothing Plane
Which Woodmizer?
Which Woodmizer?
Which Woodmizer?
JKJ in East TN
>I've read some comments on WC from people using bandsaw mills. I'm in the market for a small sawmill for farm and personal use (no lumber production!) I was about to buy a portable Ripsaw but am leaning towards a less portable saw, primarily because of the log capacity. I have a tractor with a loader and I think I can get the logs to and on the saw OK. I do not have the budget or need for a full-featured mill with hydraulics. I will probably set it up in a permanent location behind the barn.
The Ripsaw claims just a 14"x9" throat with a 20" diameter log capacity. This doesn't seem big enough since the trees I want to harvest will generally be larger than 20".
The WoodMizer LT10 claims a 24" diameter log capacity with cuts on cants up to 19.5" wide, manual push, 7.8 hp engine. About $4000.
The WoodMizer LT15 is more expensive, but indicates a 28" diameter log capacity with cuts on cants up to 23" wide, hand crank. 13 or 15 hp engine. About $6000.
Does anyone have experience with either of these? Is the 7.8 hp a serious limitation? Should I look at a brand other than WoodMizer? All advice and experience very much appreciated.
Re: Which Woodmizer?
Kevin Turner
>try this site.( variety of saw mills available) and in CDN funds..May be cheaper cost wise.. www.enercraft.com
or ( 800) 387-5553. Hillsdale Ontario, Canada, LOL 1V0
jeff jilg
>I used to use a portable bandsaw mill with a buddy. Make sure that the mill provides a water drip system so the cut gets lubricated. One very nice feature on the mill we used was auto-advance of the whole head at different rates. Pushing the head back and forth by hand can get real tiring if you are cutting for more than 2 or 3 hours.
The whole process is a lot easier with 2 people. If you cut long boards it's just easier for 2 people to move them. Of course long boards really are not that usable since most furniture is 6' or less. Since we were targeting use in the home we cut the logs to 6' or less. It made it much easier to move the log around as well.
tdaniel
>I just sold my Woodmizer LT40HD after 11 years. I would suggest that instead of buying a saw that you contact Woodmizer and Baker and get a list of the sawyers in your area. When you get a stack of logs together hire a mill owner/operator to come to your place and saw for a day. Since you have a tractor with loader you can keep the logs coming while the operator runs the saw. One of you will have to hire some labor to stack the lumber and slabs but you will be able to saw about 3000 bd. ft. in a day vs a couple hundred feet with the hand-crank model.
Scott Ruesswick in NH
>JKJ, I have a Woodmiser LT30 (since replaced by the LT25 I believe) that works very well for making lumber for personal use and making bowl blanks. This mill has 28" of clearance between the guides and 14" under the headrig. With a 25 horse Kohler engine it has enough power to take on even large oak logs. It is equiped with electric powered headrig advance and reverse as well as height of cut.
I would consider 15 horsepower barely enough for 20"+ cutting of logs. Loading, turning and dogging of logs without hydraulics is tedious at times but the extra cost is more than I would pay for a personal mill. I would recommend a woodmiser mill to anyone wanting a mill. Used mills can be found at Sawmillexchange.com Scott
George Van in WI
>Like Terry I have had a LT40HD for 11 years, I woud agree that you may be further ahead hiring it done than investing in and maintaining a mill. Mine has over 1.3 million bft and has more than paid for itself. I guess if i wanted a bowl I would have been better off buying the bowl than investing in a lathe and tools also!
If you do decide buy the larger one, it will never be too big and I think you would regret the 7.8hp, not to mention no mechanical feed. Hydraulics are necessary for production, if you are not interested in production but want to do your own thing then a manual mill will cut as straight as a hydraulic and you will still end up with more lumber than you can use. A fellow in our town had the LT15 and cut a lot of wood with it without mechanical problems.
Thanks
JKJ in East TN
>Thanks for the comments. The LT-15 is beginning to look more like a reasonable fit to my budget and needs.
George, you hit on two things - I'm not interested in production, just sawing for my own occasional needs. Also, I may be better off with a simpler mill even if it takes longer. Thanks for the advice on the engine horsepower, it was as I suspected.
tdanial, hiring a sawyer to cut up a pile of logs on site would normally be a good idea, but my needs may be less demanding - I think I want to saw an occasional log long before I accumulate enough to hire a mill.
Kevin, the enercraft link took me to Baker Products and the prices listed seemed to be in US dollars and more expensive than Woodmizer (although probably better equipment). Perhaps I can find someone with experience in both.
all the mills will be on display at...
tdaniel
>Sunbelt Expo in Moultrie, GA. I think the expo is next week, Tuesday , Wed, and thursday but you might want to do a Google search to make certain of the dates. Woodmizer and Baker are always there as well as 4 or 5 other less known brands.
Re: all the mills will be on display at...
JKJ in East TN
>Do you know if the makers commonly offer "show specials"? (common at computer and graphics conventions)
George Van in WI
>They usually do have "Show Specials", sometimes only on the display models so they do not have to haul them back. You may be able to check with sales at Woodmizer to find out.
