Guard on Lathe
Guard on Lathe
Guard on Lathe
Steve Schoene
>Does anyone use a guard on their lathe while spindle turning. You know, the kind that arches over the bed, with plexiglass windows or with a wire screen. One came when I bought my Delta Heavy Duty out of a OHSA regulated shop.
Re: Guard on Lathe
Re: Guard on Lathe
albertabob
>Personally I would not use one because when the sheild gets dirty and it will, you are going to produce an accident that you would normally not have.
I suggest that you use due diligence in securing your work and always use a face shield.
That chunk of wood leaving your lathe will try for your head every time.
Don't be blinded by a sheet of dirty plexi.
Bob
Re: Guard on Lathe
Re: Guard on Lathe
tdaniel
>The guards do not stop things from hitting you; they only stop things going AWAY from you...then they return them to your face. Unless you are looking through the guard it is not giving you any protection....only the false sense of security. It is there only to protect the manufacturer against a lawsuit; it does nothing to protect the turner. Now if you are doing a demo in front of a room full of people it may protect the audience.
Re: Guard on Lathe
Re: Guard on Lathe
JKJ in East TN
>Steve,
I remember two earlier discussions here about this. (One was me asking the same question.) I found them with the search feature:
http://www.woodcentral.com/cgi-bin/archives_turning.pl?read=42449
http://www.woodcentral.com/cgi-bin/archives_turning.pl?read=68282
Re: Guard on Lathe
Re: Guard on Lathe
Steve Schoene
>Thanks guys--haven't been using it, now it will head off for "dead" storage, not precious shop space. (Do religiously use a face mask.)
Re: Guard on Lathe
Re: Guard on Lathe
Pete in Holland, MI
>Make sure not to use acrylic, or Plexiglas brand material for any guard. It will shatter into large pieces if struck hard. Use instead polycarbonate, a common name is Lexan. MUCH more resiliant to impact.
