Bummer!
Bummer!
Bummer!
Carole in VA
>My first piece off the new lathe and my first platter and the stupid thing is warping! The MC was around 12% which is about as low as you can get it around here without a kiln. I figured I better take a pic before it curled up like a sheet of waxed paper. It has not even been finished yet...only oil. Sorry for the focus...my camera wouldn't even cooperate today. :(
Re: Bummer!
Re: Bummer!
Mike Schwing from Md.
>Don't be surprised if it flattens out again within a few months. Happens quite frequently, actually. Generally, I won't ever turn anything start to finish without at least letting it sit again for a few weeks to allow it to finish drying/warping. Usually even if I think it is dry, dry, dry I will rough it to shape and then set it on the shelf again. Almost everything warps some more, but a lot of times half way through a season you'll notice it flattens again.
Re: Bummer!
So there is hope, yet! Thanks, Mike.
Carole in VA
>I won't toss it for a while then.
Re: Bummer!
Re: Bummer!
Gary Evans Tallassee, TN
>Hi Carole,
I had good luck clamping a warping platter between two pieces of 3/4" plywood and letting it finish drying. You need something between the plywood and the piece on top and bottom to allow it to breathe a little.
Gary
Re: Bummer!
Re: Bummer!
Phil Joines Krum, Texas
>Even dry wood can warp. Cutting away part of the wood can let the piece respond to internal stress. I rough platters 1/2" or so thicker than final and let them sit for a month or longer.
Re: Bummer!
Let it live, and do its own thing.....
Kevin Turner
>why is it so..... important to have it our way all the time . Let the wood speak one last time... Its' a surprise in the making...Enjoy the ride the platter will create for you...( One of a kind....deal.) My lonely candaian 0.02cents worth..Kevin T in T Bay
Re: Bummer!
The "ride" is a rocky one! :)
Carole in VA
Re: Bummer!
Don't be afraid....Try it, just this once..
Kevin Turner
>Let it go... Water it ...encourage the thing to have a personality this one last time Before you solidify its' soul...Okay,,, One to many helpings of turkey...today. Or the outlaws were trying to poison me...Could be the wooblie pops...
But serious... Let the thing do what it wants...There are more platters to be turned... Learn and watch the wood.You may see some ideas to prevent the next one from warping....Cheers KevinT in T Bay
Re: Bummer!
see....
Kevin Turner
>Carole. this is what happened to green willow . Turned in one session. Its' FUN...
Re: Bummer!
oops.
Kevin Turner
Re: Bummer!
Re: Bummer!
Russ Fairfield
>You have just discovered a couple things about a platter. That wide flat grain is the most sensitive grain orientation to changes in moisture content and temperature, and will move more than any other.
Just the cooling from turning and sanding to room temperature is enough to make it warp.
There are a couple other moisture related factors working here. I have no idea how you knew it was 12% MC, but whatever it was, I would guarantee that it was not the same all the way through the wood unless it had sat in your shop for a year. Walnut is bad about staying wetter beneath the skin. You will have also lowered the MC from the heat of turning and sanding.
You are watching the wood reach equilibrium moisture, and cool to room temperature. Both will cause movement, and the flat grain will move more. Enjoy the show, consider it a lesson learned, and try a different grain orientation next time.
Re: Bummer!
Re: Bummer!
Carole in VA
>Russ, I am a little confused about what you mean by try a different grain orientation." I'm not sure how I could change the orientation?
As for the MC, I used a moisture meter (pinned) in the center of the edge of the fresh cut blank which was about 3" in from the original edge. Maybe not an accurate location. This is maple from the same stash of maple I have been turning bowls from all along. I didn't have a problem with the bowls warping but I can see platters are going to be a whole new ballgame! Hadn't thought about the heat generated from turning and sanding on a large thin piece (although this is not that thin.) Can one expect most platters to warp at least some?
Re: Bummer!
Re: Bummer!
Earl Eyre
>Purists may not like this remedy but I've used it with great success. As others have said, first just let it sit for awhile and adjust to the environement. If it goes back round, fine. If not and you have enough of a foot on it, just hold it on a belt sander (or some other sander) and flatten the bottom of the foot so it sits flat. Presto, you have a beautiful oval platter with some personality. Most people will love the shape and you will get many more positive comments than you would get on a perfectly round platter.
Earl
Re: Bummer!
Re: Bummer!
Russ Fairfield
>Platters are more difficult than bowls because they don't have the circular global shape to restrict movement.
Something that can sometimes straighten a platter. Note that I said sometimes. Put it in the microwave or oven at 220F and get it very hot. Too hot to touch is good. Then lay it face down on a hard flat surface, and put a concrete block on the bottom. Let it sit for 2 or 3 weeks. Sometimes this will help it get straighter. If it doesn't work, it won't be any worse than it is now.
Someone already suggested that you turn the base so it sits flat without rocking. You may think it is warped, but most people will accept the warp for what it is (wood). Turn the base so it is dished and the plate is very thin in the center. This will help keep it straighter.
One other thing you can do next time with a similar piece of wood. If there is some curvature to the grain, make the shape from the other side of the block from what you did this one. That makes the line of the curve crossing the grain of the wood, rather than flowing with it. It will look different because the grain on the face of the platter will have an X shaped pattern rather than concentric ovals, and it will be more stable.
