pepper mill help
Patrick Capobianco
>What is the best way to drill the through hole in the blank? I tried using a fostner bit then I had to switch to a spade bit for extra length,but hole went off center.
pepper mill help
Patrick Capobianco
Re: pepper mill help
Jim Shaver - Oakville, Ontario
>Hi Patrick,
I use a 1 1/16" forstner bit. I drill half way from each end on the lathe using a jacobs chuck on the headstock.
I can forward my pictures of the process if you like, let me know.
take care,
Jim
CORRECTION (opps)!
>Hi Patrick,
I just reviewed my pictures (I emailed them to you by the way). I indeed use the tail stock to hold the jacbs chuck, I use a scroll chuck on the head stock to hold a turned tenon on the blank, I drilled half way in or more in that orientation, then I reverse chuck it and drill from the opposite end, I made 10 last year, they all came out fine in the drilling process.
Take care,
Jim
The Wood Spinner / Bill Hale
>You can also buy a special extension for the forstner bit. This will remove the reversing need and do a single straight drilling.
Good turning and be safe
Bill in Casa Grande, AZ.
Brian McKearney
>I had a similar problem when drilling holes through lamp blanks with a lamp auger - a bit longer drill, but same principle. I found that I needed to take VERY small bites and clear the chips prior to going further. I read this in a magazine a couple of years ago, and slow progress seemed to keep the bit running true. Not sure if this is the complete answer to your problem, but you might give this a try to see if it helps.
When I make pepper mills, I use a spade bit mounted in a jacobs chuck in the tailstock (same as you described, I think).
Brian
Re: CORRECTION (opps)!
Patrick Capobianco
>Jim, I tried viewing your pictures must outlook keeps locking up, maybe try it again.
Re Sent in 2 Emails
Basic Steps
>Hi,
I have had a few emails requests to post teh basic process. I took a class at Lee Valley about a year ago. Ted at teh Burlington store taught the class. This was the illustration he put up to describe the process.
The head stock position is to the left, with a scroll chuck. You can see how we first ceated a tenon, then parted the top and body. Using the tenon in the scroll chuck we drilled a counter bore for the mill mechanism, but also used it when we reverse chucked the mill during drilling. It also was used when the body of the mill was being turned.
take care,
Jim
