what kind of lathe to purchase?
bob harris
>i've been turning about a year and want to move up to a bigger, better lathe than the delta i now have. this would be primarily for bowls. oneway, powermatic, ?????????? if money is not the primary concern...any thoughts on this? oneway has a long lead time. powermatic looks good and is available now. any others i should consider. hopefully this will be the last i will purchase so i want it to be the right one.
Re: what kind of lathe to purchase?
tdaniel
>If your primary goal is bowls and money is not a concern I would recommend two lathes instead of one, space permitting. There are times when you need a tailstock and there are times when a bed is in the way. A sliding headstock is a good compromise if you get a really good freestanding toolrest but these are awkward to adjust. The best combo that I have found is the VB36 bowl lathe without a tailstock and a hefty 24" bed lathe for when I need a tailstock. I am constantly switching from one lathe to the other and would really hate to give either of them up. There are other specialty type lathes that may suit you better for certain types of work. I find that the combo I have gives me very few constraints and I am able to go to shows with unique items that would be hard to make on either of my lathes without using the other. The VB has a thread adapter that allows you to use any chucks you may already have with it. The best approach is to turn on the lathes you are considering before purchasing one.
TD
Re: what kind of lathe to purchase? *LINK*
Sascha
>you sound like a Stubby kind of guy.
I started on a Jet mini, then a Nova DVR and now have a Stubby 1000.
the 750 is just as great.
the versatility of the stubby can't be beat and it's a rock solid machine.
good luck with yourdecision
sascha
Stubby
georgetroy
>Why not go American made with the Robust Lathe. The 25 x 28 should serve your needs and extensions are available for extra length. This upper end lathe is made in Wisconsin. I think lead time is about 8 weeks now. GT
Robust lathes
Phil Powell
>I thought about Oneway, Stubby, VB and others until I saw a Robust lathe inperson.
I drove to where they are made, talked to the owner, messed with the lathe and layed
my money down. It's a great lathe that's built like a battleship and has many unique
features that other lathes only dream of. AND it's American made including the motor,
the controller, The bearings.......the whole thing. I should have mine within a week
or two..........can't waite!
The Wood Spinner / Bill Hale
>Oneway
Get a Oneway 2436 with the outboard extension. This will provide you with inboard between centers and outboard bowl lathe up to 48". 3hp vs ONLY WAY TO GO
Good turning and be safe
Bill in Casa Grande, AZ.
Keith Tompkins
Keith Tompkins
>Hi Bob, If you choose powermatic, go with the 24" model....nice machine. ALL the top-end machines are good, it will come down to how much you are able to spend.....
