THE WOODRAT IS BACK!
Burning questions
Burning questions
Burning questions
Mike Schwing from Md.
>I have the "B" model listed below. The pen gets so hot I cannot stand it even through a piece of foam and a thick glove.
Additionally, I think the thermostat/regulator is crappy. The temp drops off at random. I need to let the unit cool down and restart it to get the desired temp.
I'm definitely returning this unit, but I don't want to wind up in the same boat. My real question is - are all pens like this? Holy canoli, there is no way I can work with this one for more than a few minutes.
I see Dominic has a thread posted that will probably help, but it doesn't address this hot pen issue.
Thanks.
Re: Burning questions
Tony Reynolds somewhere near Newark, OH
>Same model I have. The regulator doesn't drop out on mine, but the pens do get hot! I use a glove until it gets too warm, then take a break for it to cool down.
Tony
optima *LINK*
e
>the optima units are better engineered, and therefore the heat gets to the tip instead of the handle. talk to pat at
http://www.carvertools.com/aboutpjl.htm. he might give you some further information on what you can do.
i work for hours at a time with my pens without much heat problem at all.
Dennis Taylor
>I agree that the Optima is a better unit, I got mine and use it for quite long periods of time, I don't use a glove or anything, and I burn in the mid to lower range....I don't know about the engineering of it, but I do know that I use mine and quite happy with it....Dennis
Ed Moore
>I got the Burnmaster Hawk and some Optima pens. It works fine. I also got some Razertip pens. I very much like the flexibility of the Burnmaster Hawk or Eagle, which do not come with pens, but they accommodate pens from other sources. I also think that Optima pens may have earned their name.
Ed
Molly Winton
>I have the same model you have Mike. I think you have a bum machine. Mine works just fine. I use the rubber sleeves that you can get with the pens, and I don't have any difficulty working with the pen at very hot settings for lengths of time. It'll get a bit warm after a while, but not to the point that I have to cool it off. With all the praise of the Optima pens though, I'm going to have to check them out. Exchange your machine, you could have a fire hazard.
Brian Hahn in SW Wisconsin
>I agree with Molly. I've got the same unit and pens - bought them 10 years ago. I've never had a problem with either the temperature regulation or with the pen handle getting hot. Like Molly, I use the O-rings on the handle.
Concur
Jorge Castaneda
I second the Optima
Jennifer@Indy.USA
>Thanks to -e-, I bought the Optima single unit and several of their pens. I have been very happy with both the unit and the pens. I should have a new pen in the mail this week as a matter of fact!
I also recommend the Razortip Create-a-Pen. For the Optima unit you'll need an adapter from Radio Shack, but the pen is great. I've made several custom tips with it now and am having a blast with them.
Mike if you bought your unit from Woodcraft...remember they have a one year Be Happy or Return it policy. Take advantage of that!
Jennifer
