Cool wood
Cool wood
Cool wood
Carole in VA
>A fellow turner visited today and brought me two pieces of this maple. I don't think my skills would do it justice yet so I will sit on it for while!
Re: Cool wood
Re: Cool wood
Craig Daymon
>Wow! Why bother doing anything? That's one pretty piece of maple! You're lucky to have such a generous friend. I'm looking forward to seeing what you do with that.
So what's the dimensions on that block?
-Craig
Re: Cool wood
Re: Cool wood
>CArol I was thinking the same thing. Turn a shallow bowl shape in one area and leave the rest of it the same shape it is. then just sand and finish it to the "Nth" degree. What a spectacular piece.
Re: Cool wood
Re: Cool wood
Carole in VA
>8x8x10 The other piece (just as pretty) is 6x6x7. The more I look at it the awed I become!
Re: Cool wood
Re: Cool wood
Eduardo Sarmiento Hall,lima peru
>Wow I see a cat lurking in there,just great piece of wood
Re: Cool wood
Re: Cool wood
>Really nice spalting. I guess you're collecting pieces of spalted maple now. You'll get some good pieces out of that.
Re: Cool wood
Microwaving can help to warm it up!
Clem Wixted
Re: Cool wood
Holy Moly!
Molly Winton
>I'd be intimidated too. That is some beautiful wood! Lucky cuss!
Re: Cool wood
Re: Cool wood
Ron in Drums PA
>That is a really nice blank!!!
I hope that is not a crack on top?
Re: Cool wood
Re: Cool wood
Carole in VA
>Unfortunately yes it is. But I think it can be worked around. I just hope it doesn't get any bigger. The wood is dry.
Re: Cool wood
Re: Cool wood
Norm Smith in Nova Scotia
>Hi Carol,
I have never seen a nicer piece of spalted wood. You can do it justice.
Good luck,
Norm
Re: Cool wood
Re: Cool wood
Sonja Lemon Sacramento Ca.
>Carole, That is gorgeous! I think I would try to get a piece or two of veneer out of that first. Make very nice box top. Then turn what is left. Sonja
Re: Cool wood
Re: Cool wood
Craig Daymon
>She meant a 'round' box, REALLY! No flat work here! ;-)
I was thinking the same thing after I posted yesterday. The main side showing in the photo is so fantastically patterned that it would be nice to preserve just the way it is. I'd even consider a water based finish to keep it as white/black as possible with minimal yellowing.
Quick thought, how about a turned cabinet? Turn a thick walled vessel/hollowform (3/8" maybe) out of something dark, maybe Walnut or even Cherry (with the help of a little sunlight). Straight sides, at least across the main body. With some configuration of jig or maybe a thin dremel cutting blade, cut out a "window" in the side, to about the half way point of the circumference. Now create 2 panel frames from this cut-out. Using a hot pipe, first dampen a piece of thick veneer (1/8") from the block and curve it to the contour of the vessel. Fit these into the frames. (Some reinforcement of the frames is likely necessary to compensate for grain direction weakness.)
Hinges for the doors just created shouldn't be too hard to find or make with brass pins. Shelves cut to the inside diameter can be inserted through the opening of the doors sideways and then rotated into place and glued.
Or you can do whatever you want and it will without a doubt be wonderful.
Congrats again,
Craig
Re: Cool wood
Thunder Cat!
Eddie Pacheco; San Jose, Ca.
>My son used to watch a cartoon that had a cat that the "image" in your wood piece looks like.
Re: Cool wood
Re: Cool wood
Carole in VA
>Actually, the friend who brought it used a slice of it to do just that. He used it inlayed in the top of a jewelry box.
Re: Cool wood
Re: Cool wood
Don Henthorn
>Carole, you have demonstrated that you have the skills and the eye. Such a beautiful piece of wood needs good execution of a simple form and flawless finishing and you ARE equal to the task.
Re: Cool wood
Hmmm, Pen Blank Potential!!
Jim Shaver - Oakville, Ontario
>Hi Carole,
Imagine cross cutting that into pen blanks....wow.........I'm Kidding!!
:-) .... Partially...
Have fun dreaming about what you'll make with it!
Take care,
Jim
Re: Cool wood
Arrrgh!
Carole in VA
>Be still my heart! LOL I will send you the scraps though, Jim. :)
Re: Cool wood
Re: Arrrgh!
>Hi Carole,
I was just keeping up appearances, You make sure you dream on through that wood, You are on a roll!!!
take care,
Jim
Re: Cool wood
Re: Cool wood
AnthonyY
>From what I've seen of your work, there is no way you could harm this wood. Don't let the "shape" overpower the wood
Re: Cool wood
Re: Cool wood.... crack
Ruth Niles
>Carole,
Even though the wood is dry, you might want to do something about that crack. Because of the thickness, the small crack just might cause enough stress to run down the whole piece (I've had that happen). It's just too awesome to take a chance.
I think I'd leave it whole just to be awed everyday!
Ruth
Re: Cool wood
Cool wood
Terry Quiram, Roanoke Illinois
>Carole
I don't think I would turn the whole thing. I can see some increadible book matched box lids. That is some amazing spalting.
Terry
Re: Cool wood
Re: Cool wood
Ron in Drums PA
>And I thought I was the only turner who does this.
Re: Cool wood
Ron in Drums PA
>I agree with Ruth, It's hard to tell how deep a crack is going into the wood.
Since it is a 6"x6"x7" I would cut 1" off the top (pen blanks!!!) to check what the crack looks like. From there you can see if you can do with the block. All is not lost if you have to cut it down along the crack.
Re: Cool wood
Carole in VA
>Actually it is 8x8x10 so I have room to play. I could get two bowls out of it if the crack is not too bad and I can fill it.
