Have a question? Ask Woody!
Should I be doing this differently?
Carole in VA
>This new lathe is setting me up for a whole new learning curve. I have a Birch log that I want to get round and hollow end-grain. If I get an unintetional heavier cut where there are knots, the spur center will spin in the spindle. Something tells me this is not good for my spindle. Teknatool says not to use a mallet, only firm, quick hand pressure to install the spur center. The spindle opening and MT on the center are clean. What to do?
Re: Should I be doing this differently?
>Buy a large Steb Centre. I have tried (and have) one of the medium/small ones. I really like it.
>Of course I use a wood mallet or club for my 4-prong all the time. Typically I start the center with my automatic center punch and then give it a gentle whack with my piece of ash.
Carole in VA
>I have one that I used on the Jet but it's a little small and all my pennies are gone so no new one now. I guess I am wondering why the large center that came with my lathe will not stay put. Is it defective? Is the spindle defective? Am "I" defective? LOL Will this ruin the spindle?
Ed Kelle
>I'll bet you've already tried this, but how about more tailstock pressure? I think Tekna is being a bit super cautious, I don't think that a light tap or two on the back end of the wood to seat it better would damage anything. Has this spur ever caused those problems before?
Carole in VA
>Got the TS cranked as tight as I can get it. The spur has not cause problems before but I just got the lathe last week and have not turned wnything "lumpy" until now.
Ed Kelle
>I know you said you cleaned it, but is there a chance that there is a coating of that shipping machine oil inside the spindle which is causing slippage under heavy load?
Other than that guess I am stumped
Dale Cook
>I usually use the screw that came with the chuck. I flatten the end I want to be the top of the vessel and drill the correct size hole for the screw and screw it on until it hits the outer edge of the chuck,then tighten up the tailstock. I then work on the tailstock end to form a tendon to flip around into the chuck. I don't do alot of forming until it's flipped around other than rough balancing.Good luck.
>Carol It's not unusual for a spur center to get cloged up withwood fibers. Stop and clean all that out. You might also try to sharpen the teeth on it if they seem dull. There are several ways to stop it from slipping. You can make shallow saw kerfs in the end that match the teeth. This will help. some people use the bandsaw to do this. I just use a back saw if I do this. many people use a wooden mallet to seat the spur drive. Drive it in and then pull it out and install it on the lathe. Then put the wood back on.
Another possibility is the tailstock can be slipping. Tighten it up and put a pencil mark on the bed at the headstock side of the tailstock. Then you can look down periodically and check to see if it's sliding. It's also a good idea to just reach up and snug up the tailstock occasionally. The wood will compress while your turning and this may tighten everything up and keep the spur center from slipping.
Keith Tompkins
Keith Tompkins
>CArole, is the spur slipping in the wood, or is the morse taper slipping in the headstock? If the spur is slipping, shorten the point in the center; usually adjustable with a set screw.
If the taper is slipping, try another spur center, or clean the taper thoroughly.
Never hammer against the bearings in the headstock, tap the center into the wood on a solid surface OFF the lathe.
Bruce Wiseman
>I've been hammering my teknatool drive spur on to the piece for a couple of years with no damage to the spur. I use a wood mallet to do it. With wet wood I still get slipage and sometimes you have to take it off the lathe and clean wood fibers off the thing to get it to hold. I know you said you're out of money but I purchased a large 2 prong drive spur that fits into my chuck jaws. (Got it from Packard but Best Tools also has them). Since then I haven't had a piece of wet wood slip. Good luck.
Bruce
Carole in VA
>The MT is slipping in the headstock. I have cleaned both thoroughly with a degreaser.
JKJ in East TN
Carole,
You can buy a great little morse taper cleaner that is sort of a plastic reamer. This is great for keeping the taper in the headstock clean.
I would never hit it with a hammer to seat and tightening the tailstock too much doesn't seem good for the bearings. Did you try just rotating it back and forth by hand while pushing it into the headstock to seat it? When I do this to mine, it really grabs nicely.
A new taper and spur center may have a tiny burr or irregularity keeping it from seating properly or they may just be too smooth and slick. I would not hesitate to dress the metal surfaces with some fine sandpaper for a better fit or bite.
Unless it is jet black, to check if the taper on the spur center is seating well in the lathe spindle, clean the tapers and coat the spur taper with dye - Sharpie ink works well. (I like blue!) Insert and twist back and forth while keeping the lathe spindle from turning. If the ink is only removed in a few high spots or rings, one or the other may need to be dressed. I'd recheck with a few differetn MT centers to see if the problem is in the lathe headstock or the center.
ben d
>bet the problem is with the center. When you insert it in and by just pushing tight if you can wiggle it then the taper is not correct on the spur. If it is just a wee bit loose you could probably salvage by drilling a hole and tapping to 1/4 and use a piece of allthread going through the headstock put a nut on it and hold it secure. I am supposing there is a hole through the head stock.
Had the sme problem with Jet 1442 when using other brand tapers but the Jet works fine. Something to consider.
My 2 cents worth
Thanks, John
Carole in VA
>I will try the marker thing tomorrow. I hope it is the center and not the spindle. I tried my small Steb Center but that is just to small for that green log and it doesn't get enough bite for the weight. BTW, if you are going to leave a piece on the lathe overnight, should you release the pressure on the TS?
>If both surfaces of the MT are clean (no grit, no lubricant), and if you have pressure from the tail stock (just a little will do it), then a properly machined Morse taper will not slip. They hold just fine in metalworking lathes, often with a lot more torque than you can apply with a wood lathe. I suspect that one of the pieces of the MT connection was improperly machined (or maybe worn from abuse). The easiest way to find out which is to find another tool with a male MT (e.g., another spur center, or the Jacob's chuck from a large drill press), install that in your lathe and try turning with it. If you still get slippage, it's the lathe (ouch!), not your spur center. Alternately, take your spur center to someone else's lathe, and try it there.
Me too. I love the 2 spur chuck held drive.
Al Crandall- NE of Indy
>I always make it a habit when mounting a large piece to lock the spindle and then rock the piece forward and backward slightly while aplying pressure with the tailstock. This helps to seat the spurs into the wood deep enough that they don't loosen easily while turning. It won't help if your drive is spinning inside the morse taper, but since I'm not using the taper, I thought it was worth mentioning. I also don't locate the two spurs cross grain since they grip much better with the grain.
>I probably wasn't clear. I whack the back (taper end) of the center while the piece is not on the lathe.
However, from all subsequent discussion, it sounds like you have a slight mismatch between tapers. If the taper for your tailstock is the same, try taking your live center out of the tailstock and fitting it in the drive spindle. It should seat snugly and firmly. If it doesn't, it may be that the drive spindle's taper is slightly off. I hope this isn't the case. It's easier to replace a center than a drive spindle.
JL: A really basic question
Garrett in Victoria
>You mentioned your automatic centre punch. I have a couple of them and embarrassed to say that I haven't got a clue as to how they are used. Can you offer instructions?
TIA, Garrett
Re: JL: A really basic question - you're kidding?
>You're kidding right? I have two. My stepfather's and mine. You adjust the tension spring (typically by screwing in and out the collar). You then put it on your carefully marked pencil mark and push it in. The spring trips and punches the hole - to whatever predetermined depth you have set. I always use it to give me a hole for my live center and my drive center. Too many instances of - did I really align the point of the centers with my pencil mark?
Re: Thanks, John
JKJ in East TN
>>...if you are going to leave a piece on the lathe
I can't imagine that would matter much, unless you had REALLY cranked it tight, which would not be desirable anyway.
Dick Hines
Dick Hines
>I have one of those plastic hammers with shot inside. I put my drive spur on the center mark and give it a couple of licks with the hammer. The plastic end does no damage to the spur.
>Carole, I have the same lathe, only two or three years older. I am not aware of having the same problem, but for no real good reason I did not like the drive center Technatool sent. Sort of short and stumpy and the spurs were short. I had an older on that must be about half again as long and I have always used that.
I think the idea of setting the spur in the piece of wood first and then put it on the lathe and locking the shaft and rocking the piece of wood back and forth is a good one. With some pressure on the tail stock, this will tend to set the spur in the wood and the taper in the shaft. Also try to use good tool control and take light cuts. it's hard to do on lumpy wood and I occasionally stop my lathe dead in its tracks. I mark the spurs on my center so that I know which one is which. I mark the blank so that I put the same spur back in the hole it came out of. Might be silly, but its a "habit or work". Actually seems to make a difference on small spindles.
Try inking the spur as suggested and see if the spurs is poorly machined. I'm sure Technatool will make it good either way. Contact Tim Geist for help if you must. I'm sure I have his number if you need it, he's their rep in the US.
Incidentally, I don't see how you could damage a spur seating it in a block with a mallot made of wood or plastic. Eventually you will need a new mallot, but it won't hurt the spur.
If you want I will send you my Technatool spur to try, but I imagine its the same as the one you have.
One other thing. Don't do what I did. I left a nice green blank on the lathe in a chuck with a plastic bag over it for a few days while I went on with my real job. The moisture went into the hollow shaft and rusted it very nicely. Had to buy one of those plastic reamers someone mentioned and clean it out. Fortunately, there doesn't seem to be any real damage, but it was a nasty surprise.
Carole in VA
>Hi Barry,
I did not like the looks of that spur center when I took it out of the package! It is definitely dummpy looking.LOL Tonight, I chalked the center and friction turned it. The chalk was removed only in one place near the front of the taper. I then dug out my old Jet spur center and did the same thing. The chalk was smeared evenly along the taper so it must be that the Teknatool center is not machined properly, which is a relief. I am assuming that the spur center taper is made from a softer metal than the inside of the spindle.
When you say you have stopped your lathe dead in it's tracks, do you mean that mechanism kicked in to stop the lathe in case of a big catch? That has not kicked in yet on mine and I am wondering if it even works.
Good tip about leaving green wood chucked up! I will remember to take it off the lathe.
Guess I need to get one of those cleaner things. Also need a new toolrest. Spent about an hour today filing and sanding that TR and I still don't like it. There is no place for my fingers.
Garrett in Victoria
>Told you I was embarrassed. And no, I wasn't kidding.
Believe me, if you've never seen it used nor had it explained, even though it is simple and effective, it is not obvious.
Thanks for the explanation.
Cheers, Garrett
