A Little OT Vacuum Pump Oil????
Randy Privett
>I picked up a new, well new to me, lets call it bigger vacuum pump.
The guy I bought it from had drained the oil. I was told I needed Vacuum Pump Oil. I didn't know it was that expensive... Is this a gimmick or what. They want $15.00 for a quart. Can I use something else?
Randy
Re: A Little OT Vacuum Pump Oil????
>It isn't advisable. Vacuum Pump oils are typically synthetics. They are formulated not to break down under vacuum and heat. You think your oil was expensive? Try diffusion pump oil (diffusion pumps are a type of vacuum pump for really high vacuums, they are not mechanical) - anyway - that's real expensive.
Also, you don't want the additives typically found in motor oil, even a synthetic motor oil.
>Fisher Scientific sells their Fisher Brand for about $11/liter and Aldrich sells it for $20.
Bill Turpin in WNC mountains
>Vacuum pump oil has a low vapor pressure. Oil with a normal vapor pressure will compete with the pumps capacity to pull a vacuum. The vapor pressure produces fumes out of the crankcase that raises the suction pressure and ruins the vacuum. Try a refrigeration/HVAC wholesale supply house. The oil they sell is ment to be disposed of quickly after moisture contamination, so it may be cheaper. Try to get them to sell at wholesale, not retail. Be sure you impress upon them, that you are NOT competing with their normal customers.
Bill in WNC mountains
Robert Simmons
>Yep, diffusion pump oil runs anywhere from $200 for the cheap stuff to $1300 for 500ml. That's one of many good reasons to change over to turbo pumps for high vac stuff. I'm happy enough with my plain old oil filled vacuum pump in the shop. $15 or $20 for a quart of regular vac oil doesn't look too bad by comparison.
Robert
