THE WOODRAT IS BACK!
Powermatic 3520a
Powermatic 3520a
Powermatic 3520a
Terry Cook
>I just bought a powermatic 3520a lathe. It will be deliverd to my local dealer in about a week an half. I'm thinking that I will need to remove the legs to get it in my van. Can someone tell me the size of the bolts that hold the legs on. Thank you
Re: Powermatic 3520a
I moved one in April
Clem Wixted
>Terry,
Good purchase.
That is one heavy machine. I removed the tailstock, banjo and headstock, as well as the legs. The headstock is real heavy so I removed the motor also. There are only two wires that need to be removed from the motor and it made moving the lathe a one man job, if you have a wheeled cart that you can put all of the parts on, one at a time. My cart was the height of the ways with the legs attached so I just had to slide on the headstock and tailstock (with a little manuvering).
You can download a copy of the manual from the Powermatic website.
Clem
Gary in Zirconia, NC
>They are 8mm allen head.
Re: I moved one in April
Tony Reynolds somewhere near Newark, OH
>I had 4 wires going to the motor on mine. Black, white, red, and green.
Yeah it's a one man job if you want to see stars. :) I just moved mine again to the new shop. What a toad.
Tony
>Terry You'll have to remove more than the legs if do it by your self. The bed is about 250lbs. The headstock with motor is a very awkward 160lbs. The legs are around 90lbs each. It's a great lathe but it's heavy to move.
Barry Turner
>Dang........that's heavier than any of the Stubby 750 pieces..........
WOODNUT358
>I moved mine all alone down to my basement shop.I removed the tail stock,then removed the whole head stock,no need to remove wires.You just need the two hex wrenches(one for the legs,One to remove the stops).I used a big plastic barrel with rope handles.I put an old comforter in it and just laid the head stock in it.I then removed the legs and placed the bed on a hand truck and wheeled it down the stairs.Just make sure you have a piece of MDF or plywood to lay the bed on when you reattatch the legs.It would help to have one other person,but it is doable alone.Good luck!!!! Great lathe by the way,I love mine.
Jay in TX
>Tony! Hey what ever happened to that big lump of Osage Orange I gave you a couple years ago? Did you ever get to sell the 3000? I ended up putting off the purchase/upgrade for a while... and moved up to the PM 3520. I am glad I waited. I think the visit to your shop put me over the edge and showed me it was worth the wait/weight.
>Hi Jay! Still have the Nova and the wood. It's sealed and waiting. I haven't been around much on here. I've spent the last 5 months or so building a new building for the shop. Just about have everything moved in now and ready to go. It's 35' x 70' with 12' ceilings.
Glad you got the 3520. I knew that's what you really wanted. I decided 2 lathes was a good thing. :)
Tony
Dick Hines
Dick Hines
>Your lathe should be on a shipping palet. At least mine was. I made a frame out of 4x4's and put wheels on the bottom. The guy at Wood Craft used their palet jack to put the lathe on my frame. I then took some dry wall screws and screwed the palet to my frame. We just rolled it all on my utlity trailer.
When I got home I used a block and tackel set to roll the lathe and wheeled frame off the trailer. To get tje lathe off the palet I used a come a long and a piece of cloth wrapped chain and lifted the lathe off the palet and no to the floor.
To get the lathe where I wanted it in the shop I pulled my truck up to the door and hooked the block and tackle to the tow rings of my truck and pulled it where I wanted the lathe to sit.
The lathe was all in one piece. Except for the help at Wood Craft I did it by my self. Just pay attention to what you are doing and be careful.
Terry Cook
>Thanks everyone. Did't even think about the stops,are they 8mm also?
Ed Moore
>Terry,
Consider renting or borrowing a small trailer and load the lathe on that and strap it down good. Offer to buy lunch at Subway or something, but get a bunch of guys together who can help you.
A friend got his new 3520A home and in the shop. He removed the bolts on one side that secured it to the pallet. While walking around to do the other side, the lathe started to lean over and kept on leaning until it fell, despite his best efforts. Apparently the pallet collapsed. This is not a one man job.
Good luck, enjoy the lathe,
Ed
