Fix soft wood (punky)
Bob R
>A friend knowing that I have started turning wood gave me a bunch of diff. woods. This is great, but some of it after roughing looks great but there are a few pieces that are pretty punky or maybe I should say are rotten. Is there something I can apply or soak them in to make them finishable (is that a word).
Thanks in advance
Bob R
PS This site is a great learning spot for us new to turning Bob:
Re: Fix soft wood (punky)
Turner in Dak
>I'm new here to. Same problem.
Help with punky wood.
THE J
Wally Dickerman in Arizona
>I have sucessfully "saved" soft, punky wood by first rough turning then soaking for 24 hours in a solution of 50/50 white glue and water. After drying for a suitable period of time, I've found that it not only firms up the wood but often small cracks will disappear. If the wood is too far gone to rough turn it, then it's probably not even good firewood.
Wally
>There seems to be 3 things that most people are using. soak it with Thin CA glue. I often use this on small areas. Works good but can be harmful to you is expensive. It is also harder than the wood so you need to be careful when sanding because the CA soaked area may stand proud of the other areas if heavily sanded. If you don't cut or sand it all off the surface it might leave a stain that will show through your finish.
Soaking the area with multiple coats of thinned lacquer. This is what I use most often. I thin the lacquer with Lacquer thinner about 50/50. It's not critical you just want it thin enough to penetrate the wood. This penetrates really well but sometimes takes longer than you think to dry so give it plenty of time. It tends to clog sandpaper so cut and shear scrape as much as possible before sanding.
I've never used it and it may be in Russ's Corner over in the other articles section, yellow glue mixed 5a0/50 with water. I believe he lets it sit over night. Since I haven't used this method I can't tell you the advantages or dissadvantages.
Dale Cook
>I also have had good results with thinned white glue (weldbond) or thinned lacquer, and sometimes both of them. Good luck.
Turner in Dak
.Bob R
>John
T A L (THANKS A LOT)
I now have a lot of wood to turn, now that I can save it. Times are tough right now.
T A L. John:
Bob R WestMacTurning
.Bob R
>Wally
TAL
I now have lot of wood to try to learn to turn on.
Bob R West Mac Turning
RevDoug
>Bondo makes a product called Rotten Wood Stiffener. I am able to find it at Lowe's in the paint section. Use it mostly to stiffen corn cobs for turning pens. Not sure that lacquer or white glue isn't just as good and a bit cheaper.
Turn 'em round,
joaz hill
>Minwax Wood Hardener works for me.
woodspinner/ Bill Hale
>Bob
Unless it is a special piece why not just throw it in the fire wood box ? Don,t waste mony trying to fix poor quality cheap wood.
To much good wood to worry about junk.
Good turning and be safe
Bill in Casa Grande, AZ.
White Glue
David Propst
>I have used Wally's recommended method of soaking punky wood in 50/50 white glue with great success. It firms up the wood very nicely with no plastic type effect at all.
Also, when using an oil finish, I have also found it really evens out the look of the wood from end grain to side grain on very absorptive woods like poplar.
David
