New Angle on Sharpening Ellsworth gouge
W.C. Turner
>I found this on an internet search.
http://www.dongeiger.com/geigerssolutions.html
Has anybody got one of these or ever used or seen one?
W.C.
Re: New Angle on Sharpening Ellsworth gouge
>No but I've been drooling over it. I've seen Don at a couple of symposiums and the jig works great. It allows you to consitently adjust for wheel wear. The main reason I want it is for traveling. I can adjust the jig to fit any grinder with the wolverine jig no matter what size stone they have. Then I wouldn't need to haul mine along.
What I really like is his stone trueing jig. I think it works better than the other ones.
Mike Schwing from Md.
>I spent a good bit of time with Don at the KC symposium, and am bringing him up here (hopefully) for a day long sharpening/gouge demo for our club. His jig is very nice, if you already have the Wolverine. It allows for exact duplication of the proper angles easily and quickly regardless of wheel diameter. I'm considering buying two because keeping the same angles on my high speed grinder and on my Tormek is not an easy task. This would make it super duper easy.
Don has put a lot of thought into his device(s). I think they're good ideas, well built. Most people I talk with about them think they're overpriced. I don't object to the price.
I don't have the Wolverine system as of now but if I did I would already have at least one of those jigs.
two ton tommy
>They had them at Arrowmont this Summer when I took a class with Trent Bosch. It worked great. Allowed you sharpen on the same grinder regardless of whether you used the Ellsworth grind or the vari-grind. If you are like me, it was no hassle to sharpen the Ellsworth on my 1/2 gouge and to reposition for to use the vari-grind on my 3/8 or 1/4 bowl gougle.
Bruce McElhaney Spring Lake, MI
>I also used one at Arrowmont, but was less inpressed. The adjustment for grinding wheel sizes was a great feature, but the jig's base sat higher than my wolverine jig. It caused my tool's contact point on the grinding wheel to be higher than my Wolverine setup. The result was that the grinding angles were slightly different from my Wolverine jig. Maybe that was just me, but it was a problem.
>Bruce,
The jig is ONLY for use with the Ellsworth jig and the Ellsworth gouge profile. It should not be used with other tools or jigs/holders like the Vari-Grind because it will, indeed, give wrong angles. I would have gotten one, but for the fact that I won't spend over $100 for a jig to sharpen a single tool. I modified the mount on my Wolverine slide so that I can use David's jig holder anyway. Since I don't travel with turning tools, it would not help me in that situation.
M
