Carter Guide Followup
>Received the Carter replacement guide set for my JET 18 today. Took all of 10 minutes to install and adjust them. Comments about them being noisy were apt until I got them adjusted so that the blade was making contact only when pushed. If you set them for continuous contact with the blade, they make a real racket.
I will note that they are loads easier to adjust, both top and bottom, than the old euro guides were. The lower set, while easier to set, is significantly lower that the old thrust bearing, meaning a longer stretch of unsupported band. I will run it this way and see, but I suspect that I may try to raise the lower unit with a piece of 3/4" plate to bring the thrust up closer to the table for greater beam strength.
M
Re: Carter Guide Followup
JKJ in East TN
I don't think I replied to your earlier post, but I bought and installed the Carter guides for my Delta saw and did not like them for that very reason. I returned them and have been using the fiber cool blocks instead which work well for me. The Carter would probably be OK (or better) if my primary use was resawing.
Garrett in Victoria
>My 20" 3 HP bandsaw came with Carter knock-offs. After ruining several bands that twisted when cutting turning rounds, I concluded the bearings didn't offer enough contact to keep the band aligned when under side pressure. I took them off and used the mountings to install home-made cool blocks. Easy to adjust, quiet, and have never twisted a band since. Oh, and the cost?? 10 minutes to turn the blocks.
Cheers, Garrett
Re: Blocks vs Rollers
>Garrett,
Since I don't use my saw for "rounds" I don't think I'll have the same problem. Interesting solution, however. How do you tighten the blocks in the guides? The Carter mounts don't have a threaded hole that would allow use of a setscrew against the block material.
Mark
