A suggestion for Carole and other DVR owners.
>Carole, How is the new DVR treating you? I have a suggestion.
The indexing pin is handy as a spindle lock. Don't get too heavy handed on it because you can bend the pin or worse, but I have been using mine as a lock for several years and have not damaged it. I did unscrew it and it fell down inside the head stock. Here is the tip.
Set the knob in the "shaft locked" position. File a notch in the knob that you can feel. Make the notch toward the outboard shaft or hand wheel. I know many of you are probably horrified at the idea of taking a file to your nice new or not so new lathe, but take my word for it, you will like it. I find myself feeling for the notch rather than looking at the knob and there is nothing to see anyway. Before I made the notch, I turned the nob round and round trying to find the spindle lock position. That's how I unscrewed it.
Re: A suggestion for Carole and other DVR owners.
Carole in VA
>LOL Sounds like a good suggestion. I didn't realize that it would unscrew. Which way unscrews it? Never know with Teknatool...some of their things turn backwards! I don't want to do it unintentionaly before I get around to marking it!
>I always turn mine clockwise now. Have not unscrewed it since the one time. When I put it back I snugged it up pretty good and that may be the answer, mine may not have been as tight as it should have been from the factory, but I have heard of others with the same problem.
I also converted mine to 240 volts and I think it was worth it, but I'm not really sure. Did not get a huge increase in power but maybe a little.
I wish it had a single button that turn it on and off. Just one thing to push that started it if it is stopped and stopped it if it is running. I actually wrote to Technatool and suggested a number of changes.
I suggested they change the switch as I mentioned and then use the remaining button for a "pulse" on and off. Have it turn the shaft about five turns softly. Put on and face plate or chuck and touch the pulse button to spin the shaft for you. Am I getting lazy or what?
Keep the saw dust and shavings out from under the shaft lock knob. The holes are in the head stock and the pin is in the knob, looking down. If you let it crud will get in the holes and you will have to blow them out. I suggested to the folks down under that they put the pin in the head stock and the holes in the knob and that way they would stay clean.
Another idea for DVR owners...
Peter Teubel
>Take one of those rubber "feet" you usually put under an object to protect a table surface and stick it to the OFF button. That way if you are reaching blindly to shut off the lathe in an emergency, you can "feel" the OFF button easily.
Carole in VA
>I generally leave my master switch on all day and just cut it off when I close up at night. I haven't found much that annoys me except that stupid tune it plays everytime you stop and start! I do a lot of stopping and starting and that tune bugs me. The delay on reverse also is a bit annoying but I guess that does serve as a good warning. I can't see any real need for 240. Seems to have plenty of power as it is. I need to get a surge protector for it before some voltage anomally in the lines messes up the computer.
Re: Another idea for DVR owners...
Carole in VA
>Good idea. I still don't like reaching over a spinning workpiece to hit the off button. I find myself reaching for it in the location where it was on my Jet mini! LOL
>I like it! I like for this stuff to be "tactile" I want the switches to work easily and by instinctive feel. I like keeping my eyes on the work. I will try this. I had suggested to Technatool that they make this a "slap" switch so you couldn't miss.
Carole, the song wears off after a while. I don't notice it any more, but it was annoying at first. Or maybe I am going deaf.
Re: Another idea for DVR owners... *LINK*
Walter Ahlgrim
>I started with a fixed stop button when I upgraded me stand I upgraded to a remote control (Stop, Start, RPM up, RPM down FWD/REV) More info at the Nova owners group.
Tip: Fast reset RPM to 500. Hold either up or down button keep it pressed then tap the stop button and the RPMs are reset to 500 then let go of the up/down button.
NovaOwners
Tom Minehan
>Instead of using the indexing pin as a spindle lock insert the knockout bar through the two holes on the headstock handwheel. It will wedge itself against the headstock lock pin and provide a much stronger lock. If your stand is not long enough to keep the bar from falling through you can turn a knob for one end. Also the Nova users group archives contains information on upgrading the locking levers. Cost was in the $25-$30 price range and worth it. I think it was in the Sept. 2003 time frame.
Re: whoops, saw 'DVR' and thought hey, TIVO!
Ned Bulken
matt fallon, li ny
>heh,ditto,thought there was a new turning show.
