We value your privacy.
>So how and where do we spot these creatures. And are all burls good burls. I work in an area where there is a lot of land development and have seen way too many trees go. At the time I wasn't into turning and have only now started to begin with bowls. Have done some spindle turning though. If you cut a burl out how do you preserve it. I've got a couple of large Spruce burls that came out of Alaska 20 years ago but unfortunately they have splits in them since the guy kept them in his attic. He also gave me some Diamond Willow(is it any good)? Back to Burls: I'd like to start taking advantage of the resources I see beingg pushed over by dozers and then ran through a larger grinder/chipper to make mulch. Any quick tutorial so I can go out and save some of the burls and or crotches? Thanks, Brian
>1.) cut them longer than you need. If a burl wraps around a tree/branch, leave a foot higher and lower on the log. Splitting will probably occur along the pith, but not for 12"
2.) If you seal the ends of the cuts, you'll reduce splitting even further. Anchorseal is the brand of choice in my house.
3.) Same for crotches. Leave some space on the ends...
4.) store the wood outdoors, but covered, and off the ground unless you like bugs. Stand the log sections vertically on the end grain on blocks/stickers...
>IMHO: Most softwood burls aren't that great; they usually are just swirly grain rather than buds. Many times a burl can be harvested wholly or partially without felling the tree, just lop 'em off. Coat both the tree and your burl asap with end sealer.
What burls are available depends a lot on where you live. Here in the Northeast, we get quite a few burls from Black Cherry, Yellow Birch, Boxelder, Hard (Sugar)Maple, Red Maple, Silver Maple, and lots of Willow and Spruce burls. I like 'em in about that order, but that's just my 'pinion...
Out West they get huge Big Leaf Maple burls (MUCH softer than Sugar Maple, and more like Boxelder), and other species considered exotics here.
Cherry burls seem more prevalent when Cherry trees grow in damp areas with poor soils, mixed with spruce and pine, in my experience, and once you find one, you are likely to find more. Some areas have no burls, others have a burl on every other tree (I'm not telling where!) I've seen great Boxelder root burls at the bases of leaning or stressed trees -- same for Yellow- and White Birch.
I find trunk and branch burls easiest to spot in early winter or early spring (no deciduous leaves to block the view), right after a light snowfall -- the burls will often have a little roof of snow that contrasts with the darker bark of the burl. If you look at enough White Birch trees, you'll find root burls -- look for a widening at the base at ground level, and small shoots, or suckers, growing up like a bunch of tiny saplings surrounding the base of a tree -- a good sign.
