Search
Search
Search
W.C. Turner
>Why is the search function so pitiful on this site? I type the exact subject line in & date, & it still comes back nothing found.
Re: Search
Re: Search
>Barry I thought it was just me. I can never get a search to work on almost any site except google and sometimes ebay. I went to MSC the other day with a part I knew they carried and it came up blank. I went home and looked it up in their catalog and then used the part # and it found it. How bad is that.
Re: Search
Search for what?
JKJ in East TN
>I've usually been able to find specific messages with the search hear, however all messages from one period of time are missing, or at least they were missing the last time I tried. Perhaps your message is in that block. I forget the dates affected.
Why don't you post the date and exact subject line you are looking for and either someone will be able to find it (and tell you what they did) or Ellis and company can check and see what the problem is and if there is a solution. I'm suspect he would be interested.
Re: Search
Maybe its in the Archives *LINK*
Jay in TX
>I think that after a certain amount of time (don't know how much), items are moved from the active board to the archives. Try to find the info you're looking for in there if you can't find it here. The link to the archives is below, or you can go the the Woodcentral Main Page and click on Message Boards, then once the message boards page comes up you will be able to find the "Turning Archives" link on the left hand side [if you are using frames]. I use frames so I don't know how its set up without them running. Good luck.
Woodcentral Turning Achives
Re: Search
Re: Search *LINK*
Ken Grunke from SW WI
>You can use Google to do a site-specific search, it works great I just tried it.
Type your search term(s) first, a space, then site:www.sitedomain.com
So, try this:
W.C. Turner site:www.woodcentral.com
And you'll come up with the following:
Search Results for W. C. Turner on Woodcentral
Re: Search
Re: Search
W.C. Turner
>Well, it was me. I didn't realize about the archives.
I was looking for Al Crandall's posting about the (subject) "Truck crane for log loading *Pic*"
He was responding to posts by Phil Murray about hurting his back loading "Free" wood. Date was 2004, Phil's was in early May, I did find that one. Al's might have been June, I didn't have time to look yet.
Re: Search
Truck crane post  *LINK*
JKJ in East TN
message
Re: Search
JKJ...
W.C. Turner
>That's it John, Thanks.
It must be great to be a computer whiz, as well as a Good woodturner!
W.C.
Re: Search
Re: JKJ...
JKJ in East TN
>No whiz, just persistence and luck. I went to the Search feature on the left panel, chose "Earlier Turning Posts" under Messageboard Searches, changed "Messages containing keywords" from ANY to ALL, and typed "Crandall truck crane" (without the quotation marks).
Re: Search
Re: JKJ...
W.C. Turner
>John,
I just tried the same search you did, according to your directions, & the search still did not pull it up. I'm glad you were able to locate it. Thanks.
W.C.
Re: Search
Re: JKJ...
woodspinner/ Bill Hale
>W.C.
I mounted mine in the truck bed. I held it behind the wheelwell and I can swing the boom to the side, out of the way, for normal truck usage. One thing you must do is to make two mountiung plates for the install. Mine are about 10 x 10 mounted top and bottom. The bottom one is braced to the frame. Without the plates the bottom of the truck bed bends and failes to provide a structural mount.
If you want drop a note and I will send a pic.
Good turning and be safe
Bill in Casa Grande, AZ.
Re: Search
Re: JKJ...
JKJ in East TN
I just retried my own directions and got the same results. Maybe I didn't explain well enough or you are doing something slightly different. Here is more complete list of steps:
- click the Search link in the left panel
- under "Messageboard Searches" choose "Earlier Turning posts"
- click "Search", brings up "Message Index Keyword Search" page
- leave the default date range, 11/19/00 to 6/12/05
- under "Messages containing..." change ANY to ALL
- in the text field, type "crandall truck crane" (without the quotes)
- click "Search Messages"
This resulted in 9 matches. The message "Truck crane for log loading. *PIC*" is second from the bottom. What do you get?
Re: Search
Re: JKJ...
W.C. Turner
>OK, John,
It pulled it up this time, only got 2 results though, not the 9 that you got.
The first time I changed the default dates, I didn't change "any" to "All". So, this, among other differences, in the way I searched, was the culprit, evidently.
I still don't understand how this works though. I would have thought the default dates should be changed to the range in which it was posted? And, I thought "Any" would work also.
Thanks again.
W.C.
Re: Search
Re: JKJ...
W.C. Turner
>Bill, I sent you an email.
I made one like Al's last year. I misplaced this posting, that I wanted to save.
Thanks,
W.C.
Re: Search
Re: JKJ...
JKJ in East TN
The default date range did include the date you mentioned, at least it did for me. I have no idea why you would get different search results with the identical input - this doesn't make sense to me unless some previous change you made to the date range was saved and resulted in a slightly different date range, or
Date range: It would generally not hurt to leave the date range as wide as possible to avoid omitting a post - the only downside I can think of is the search may take a bit longer.
ANY/ALL: as long as you are sure about the words, ALL should narrow the search to far fewer messages than ANY. ALL means find only those messages that have EACH of the keywords you typed while ANY means find message that contain any one of the keywords you typed - this has the potential for finding way too many messages to be useful, especially if you include more words or common words. If you are unsure of the words, the ANY option might be better.
