We value your privacy.
>Being new,(1 1/2 years turning) Why does the baby finger / that side of the hand ,feel like it is on fire, (When turning the solid ring on my segmented bowls)? Is this due to the tool? the amount being cut? the tool rest height? Just wondering if I'm not doing something propperly. Thanks kevinT in T Bay
>If you leave it there too much longer it just might be on fire.
Turning dry wood creates a lot of heat, as you have discovered. The heat is transferred to your hand by the tool, the shavings, and the air. As you progress, you'll learn different ways to present your tool so your hand isn't in the line of fire of the shavings.
Sometimes I just have to stop for a spell, which makes for a good opportunity to sharpen the gouge anyway. I have also resorted to a jug of water into which I dip the tool to release the heat.
Mostly though I have learned to work the tool with many different hold positions, usually one of them will suffice to keep my hand cool.
I do not wear a glove in this case, but others do. I'm a Libertarian so I don't care what they do nor do I wish to convince them my way is best. (don't flame me thank you!)
>Thanks Mike. I too head off to sharpen at this point. It never fails, It is always near the headstock ( tight corner) and you know if you attack it from the other way, it will be ugly. Water sounds like the cure all, ( hollow form / noise ) etc... Would pure beeswax be harmful to use? They use beeswax in aviation prep. i.e. touch it on hot drill bits/ saw blades etc. to cool the tool down.??? thanks KevinT
If it's the tool getting hot, as it does with dry wood, one thing I do is alternate between two gouges with the same grind to let the other cool down. This won't work if it's from hot chips. A strong fan might help some.
I also don't use a glove - I'm afraid it might get caught on something and rip my hand off.
>I don't wear gloves, Something about impeeding the ability to feel the wood etc, I've never been able to wear gloves. Only when skidooing or snowblowing.LOL.
It only seems to happen on the solid rings. Not the segmented rings. Would this be caused by end grain? Thanks KevinT in T Bay
Well, I am odd man out. I wear a glove with the lower half of the fingers cut off when the heat is bothersom. ( did you ever see a glove with the top half of the fingers cut off. I say some stupid sounding things at times) however, I find that the glove works just fine. I have had stitches a few times but was working without a glove at the time. Whatever you do, be careful. Most accidents happen when we are not really paying attention.
>Kevin- a nice tight and thin leather golf glove works wonders for protecting your hand without being a real safety hazard. And you don't have to buy a pair and throw the other one away?
>That glove will cost twice as much because it has "golf" associated with it. I use leather gloves for other things and find the right hand wears out first, being and right. I get a new pair, throw away the old right and cut the fingers off the left and use it for turning. I'm not sure whether it is more likely I would get the goat skin or leather caught in something or my skin. I know that glove sure takes a beating and I have to replace it once in a while. Rather have the wear on the glove than my hide.
Does anyone know of a real accident that occurred while turning because of a glove?
Not specifically with a wood turning lathe, but I remember the safety precautions over the years from industrial safety seminars and safety meetings. Gloves were not to be used around rotating machinery of any type. I found some of these precautions repeated on the web, references below.
I found several instances of industrial accidents where a glove was caught by rotating parts on a lathe. It might be argued that the these accidents involve machines significantly different than our woodturning lathes, but we stll use chucks with protruding jaws and turn natural edged and other odd shaped wood. It also might be argued that the same accidents could have resulted by the hand being caught instead of the glove, but that seems less likely to me, since the leather and cloth used in most gloves is much stronger than live human skin. I suspect tight-fitting thin leather gloves would be better than more loosely fitting or cotton gloves. The perfect glove for wood lathe would be snug and designed to disintegrate or tear apart easily. Perhaps some spray on skin protecter?
1995: A 61-year-old male machinist (the victim) died after his clothing was caught by a clamp on the revolving turntable of a vertical lathe... His glove was caught by a clamp, and his body was pulled against the opening between the lathe housing and the cutting arm....
From OSHA workplace services, safety convictions information site:
http://www.eric.sa.gov.au/show_page.jsp?id=2969
On 21 February 2002, a worker was rolling tyre cord using an industrial lathe when his glove became stuck, pulling his arm around the bobbin. The lathe continued to operate. Several workers attempted to stop the machine but it reactivated a number of times resulting in the worker being pulled further into the machine. The 17-year-old worker suffered two fractures to his right wrist and two fractures to his right forearm.
* When handling rough stock, gloves should be worn. However, when performing any machining operations, gloves become a hazard because they can be caught in rotating parts.
From Accident Compensation Claims, General Accident Prevention Articles,
· Know when to use safety gloves and when not to. It can be dangerous to use gloves on rotating machinery; the glove might pull your hand into the machinery if it gets caught.
16 Always remove gloves before turning on or operating any machine. If material is rough or sharp and gloves must be worn, place or handle material with the machine turned off.
