THE WOODRAT IS BACK!
Couple of newbie questions.
RJ
>Hello all;
Well, I'm gettin the hang of turning on small objects. Have been practicing on pressed wood which chips easy cause it's soft.
Making small clock finials for my clocks.
Found location to buy cherry wood which I will do soon. But a question has come to me.
I am wondering now if I can take plywood thick sized sheets of cherry wood and glue them together for small stock turning material.
Like maybe 1/2" x 4" x 12" strips and glue them together.
Originally I wanted sizes like 3" x 3" x 7" or so size stock, which would probably produce at least 2 1/2" width or less. I probably only need 2 1/2" width max.
I dont know the ratio of amount that gets taken down when corners are completely off and stock is round. Any clues on how to figure out that would be apreciated.
And I believe that 3" x 3" might not be a normal trade size. So, I think maybe I will glue some trade sizes together like maybe plywood size (thickness) together to make roughly 3" x 3" strips.
Is there any inheret problem with glueing like this? How long is glue drying time to get ok results for turning? I am guessing yes.
Glue not being dry would definitley be one, any other snags here?
What kind of glue is best? Also I want cheap. Running out of money, Is elmers carpentry glue ok?
How long to let dry? Anything speed up the process?
Thanks in advance.
RJ
Re: Couple of newbie questions.
Carole in VA
>"I dont know the ratio of amount that gets taken down when corners are completely off and stock is round. Any clues on how to figure out that would be apreciated."
If you have a perfectly square 3" piece of stock and it is mounted perfectly square on the lathe, the cylinder after the corners are removed will still be 3" in diameter...in theory. As you can probably guess, this involves a lot of "perfection" which you may or may not be able to achieve. Probably not, but knowing the above, cut your stock to give yourself a little leeway to get the size cylinder you want.
JKJ in East TN
>You can certainly glue thin stock together to make thick turning stock. The very first bowl I turned was from glued up 3/4" boards because I wanted to make a bowl and didn't know wher to find thick blanks.
One advantage, besides the thicker stock, is the potential increased strength and stability. One disadvantage is that without careful matching the glue lines may stand out. This may or may not be a problem for your application. Sometimes it can look stunning, especially with contrasting woods or grain. A friend of mine made a lamp from nine pieces of long 2x2s glued together. The curve of the turning made interesting curves at the glue lines.
It is important to get the faces perfectly flat (jointer, good plane, or large sanding disk would help) and use good clamping pressure.
Ordinary yellow glue works fine and dries quickly, overnight to be safe. You might check some web sites about segmented turning for better glue suggestions, or perhaps one of the segmented turners here may chime in.
RJ
>Thanks all;
Wow! Quick response. This is a busy site.
RJ
Don Henthorn
>Yup to what Carole said. White Elmers glue should be fine. I would give it at least 24 hours to cure although the instructions say less. Don't know where you live but most places will have tree surgeons or tree removal services and are often good sources for turning wood. Sometimes the city will have a place where they dispose of downed trees and that can be a source of turning stock. Keep your eyes open and ask around and you should ultimately wind up with more wood than you need. Of course you will probably need a chainsaw and access to a bandsaw to cut out blanks. Turning green wood is a little different than turning dried wood, but keep reading here and search the archives and you will get all the info on that you need. Happy turning.
RJ
>Hey thanks Don;
Thing is I am not sure what kind of wood I can get away with turning. I am trying to stick to fixing up my old clocks to be as original as possible. And consensus is that they used cherry wood to turn the clock finials with way back when.
However, free wood is really tempting. Besides that, it's not like I could even tell to begin with anyway.
I was just under the assumption that I probably could not find any decent hardwoods laying arround here in Florida anyway. I really have no clue.
Thanks for tip about tree removal service. Maybe I could ask them if they have cut any cherry wood trees down latley. Or do they even grow in Florida....?
I dont think I would like to turn green/wet wood. Because I want to stain and shellac them after I am done.
RJ
>RJ I've been experimenting with drying small blanks for my ornament finials in the microwave. So far I'm having good success but have only tried one type of wood, Elm. This method would be great for clock finials. I seal the ends with latex paint and cut the wood at least an inch longer on each end than I need for the finial. I start off with short periods of time on high. 30 seconds with plenty of time to cool between bursts. My microwave only has High so that's what I'm stuck with. Then after about 6 cycles I switch to 1 minute each. There's no rhyme or reason between my cycles just whenever I happen to walk through the kitchen. I probably did 15 cycles and then just let it sit for a week. It seemed to turn great. This was a 1 1/4" square piece about 8" long. Your times may vary. It did check at the end a little so make it long enough for waste. Since this is found wood cutting off the ends shouldn't matter.
Pete in Holland, MI
>Check your yellow pages for cabinet workers in the area, or check at the local board stores (not the big box types, but the ones who've been there for decades). These guys may be able to point you in a direction of a shop or two who work with nice hardwoods that you'll probably be able to pick thru their dumpster. I work with a guy who keeps tabs on several different shops. Brings home tunk loads of good turning or laminating stock for the cost of a couple pizzas or a 6-pack of beer. Bringing your work back to those places once in a while keeps the source open too.
RJ
>Man you wern't lieing!!!!
Called up a bunch of tree trimmer guys and found one that had tons upon tons of oak tree trunk sections.
One piece was near bottom trunk had to been at least 5 foot in diametor and a good 4 foot thick. I was thinking maybe you guys would like to carve out a bath tub or something :)
I imagine the shipping would be a pretty penny. I could barely cary the branch sections that I picked out. I got enough oak to make about 20 bowls and no telling how many small clock finials.
I guess my next step is to get a chain saw. Thinking I might like to have an electric one. The pieces I got are a little less than 2 feet thick.
I like the ideal of an electric one cause I dont think I will ever need to go out and cut me some wood down. Now that I know people are giving it away. And electric motor is reliable. Only problem I see is maybe a bit weak. Not sure.
A neighbor of mine had yard sale. Sold me his band saw a bunch of other tools for $5. All I need is to get the blade. Can't ask for better than that.
Thanks for advice!
RJ
Ed Karch in No.VA
>Had two electric chain saws. Smoked them both trying to make too big a cut. It may have a 16" bar just don't try a 16"cut. I wore out 4 gas saws but they all cut for years before they died trying.
JamieDonaldson
>RJ- you are already exhibiting the symptoms!!You have caught the very beginning of the "turning bug!" Enjoy, and don't hesitate to keep asking questions- turners love to talk shop!
