Shop made turning tools...
David Ramer
>... I lost all my "favorites" links to sites and articles regarding shop made turning tools... of ALL types. If anyone has links to share, techniques they use, tools they made and how, types of steel, drill rod, good places for materials or ready made bits, etc... I would really appreciate it. I don’t have the time to try and locate them all over again and am at a point where I want make my own…
Thanks for what ever help you can pass along…
Dave in the NW
Re: Shop made turning tools...
don't forget to backup the Favorites!
JKJ in East TN
>Dave,
Here are a very few links:
http://maine-web.com/woodturning/shapeshifter/scaper.html
http://www.turnedwood.com/tools&jigs.html
http://www.beaverpondstudio.com/
http://www.aroundthewoods.com/hooktool.shtml
http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=turning&file=articles_314.shtml
http://www.mcmaster.com/
BTW, losing your "Favorites" is a disaster! If you are not aware, there is a simple procedure to make a backup of the favorites. You can always copy the favorites directory, but that's more trouble. The easy way (with IE) is to use the File/Import and Export command. Select the desired folders or just select the Favorites at the top of the list to get them all. This will create an HTML with all the links. You can open this HTML file directly and click on the links, or import it back into IE if necessary.
I periodically export the links as bookmark1.htm, bookmark2.htm, etc., then copy that file to another computer on my network as a backup. This is also a good way to copy the bookmarks to another computer.
Re: don't forget to backup the Favorites!
David Ramer
>JKJ...
Thanks for the links!
yeah, Favorites is one of the areas that you just take for granted will be there... thanks for the tips on backing up!
Dave
Has anyone used...
David Ramer
>... the various replaceable tips for metal cutting tools, in their woodturning? Some are HSS and others Carbide. Many sizes and shapes. Many with holes already drilled. Any reason they could not be used on gooseneck style hollow cutting handles? Seems to a metal layman, that they could save a lot of time....
Dave
Steven Antonucci
I bought carbide to use as a bit...
steve antonucci
>But I couldn't cut it! HSS works much easier, and cuts just fine. I had a small carbide cutter shatter (inside a hollowform) on a small catch.
Steve
p.s. I make all of my own hollowing tools.
