Have a question? Ask Woody!
Bandsaw improvement
Bandsaw improvement
Bandsaw improvement
Mike Schwing from Md.
>Mark's question reminded me that I wanted to share with you a little tweak I made that resulted in quite a performance improvement in my ability to cut large round blanks on my bandsaw.
This past weekend I was rounding a whole lot of blanks (40 maybe), anywhere from 8-18" wide and 2-5" thick. About half way through I had a sudden thought about that little tool I've seen a couple of times for rounding the back side of the bandsaw blade for increased tracking performance. Sounded a bit hokey but I thought I could accomplish the same thing quickly using the dressing stone for my Tormek that I never use.
So I tried it. Just knocked off the back corners of the blade so they met at the rear and created a round surface of sorts.
IT WORKED! It really did make a huge improvement in the ability of the blade to track exactly where I wanted it to go. I was as surprised as anyone, but damned if it didn't immediately improve the saw's performance.
I don't do much else on my saw other than cut round blanks, and this is a simple, easy, and cheap (free) enhancement. Give it a try.
Re: Bandsaw improvement
Jim King
>Mike: I never would have thought of that but I am going to try it. Thanks. Jim
Vicmarc.fan
>Once I get the profile on a tool I would be lost without my Tormek.
Why don't you use yours?
Ron
misunderstood me
>Sorry, I don't use the Tormek dressing stone. I'd be lost without my Tormek, too, but that dresser - ech. Diamond credit card sharpeners work much more quickly and with better results.
I used the smooth side of the dressing stone, with the stone resting against the table, to round off the backsides of the saw blade.
Gordon Seto
>I use the grey wheel that came with the grinder.
Keith Tompkins
Keith Tompkins
>Hey Mike, I posted a while back about the BACK edge of the bandsaw blade being important to user control. I ride the back edge when cutting , similar to riding the bevel when turning. You can "steer" by using the back edge as a pivot point. I picked that tip up from a production bandsaw operator.
JKJ in East TN
>Treating the back of the bandsaw blade is recommended in both bandsaw books I have. The one closest to me at the moment, Band Saw Handbook by Duginski, says "use either a file, a diamond hone, or a sharpening stone to round the back of the blade." I use a small stone.
This is not only for easing the edge for cutting curves but for increasing the life of the rear thrust bearings. The sharp square corner can dig in and cut groves on the bearing surface. As Duginske mentions, this is especially likely to happen when cutting curves as the blade twists in the guides.
Also, a couple of years ago I had one blade that was not properly ground at the weld, making a "tick-tick-tick" sound as the spot hit the bearing. Dressing the back of the blade fixed this too. I got into the habit of doing that each time I installed a new blade.
works for scroll saw blades
Terry Quiram, Roanoke Illinois
>Mike
I have been doing that for about 20 years with my scroll saw blades when I want very tight turns with no burning. You are right it works great.
Terry
Re: works for scroll saw blades
>It would have never, ever, in a million years occured to me to try this, but I kept seeing a (ridiculous) product advertised in the woodworking catalogs specifically for this purpose. The concept sounded reasonable, but I would have never ever come up with it on my own.
I'm glad you guys validated it for me. Thanks!
