Jet Mini Ticking Noise?
Ruth Niles
>Hi,
For the past few days I've noticed a ticking in the motor on my Jet Mini. At least I think it's the motor. I'm staying at my Mom's in NJ and only have the mini lathe to turn on and I'm a wee bit concerned about the noise. I can't wait to get back home so I can use the General!
Any opinions or thoughts?
Thanks,
Ruth
Re: Jet Mini Ticking Noise?
Stuart Johnson
>Hi Ruth, I think there was something a while back about the handwheel being too tight causing a ticking noise.
Stuart
>Ruth Pull the belt off and run the motor by itself. This stick a piece of wood against the pulley to put some tension on it and see if it's making the ticking noise. I've had a motor go bad when a screw came loose inside the motor. it started making a ticking noise. Wasn't a Power tool motor it was a dust collector.
I also had a bearing make a ticking noise once in another lathe. The bearings weren't aligned parallel to each other. A machinist friend clued me in on that one. He measured them and then pressed one of them on one side a little and the ticking went away. I don't think that is your problem since they were probably installed at the factory and would have made that noise since the beginning.
woodspinner/ Bill Hale
>Do you and your mom get along OK ?
Been there to long?
Bill
Ruth Niles
>Thanks, Stuart. I tried doing a search in the archives, I thought there was a thread about noises with the mini lathes.
Ruth
Ruth Niles
>I'll give it a try, John. And thanks for reminding me of something I should have known because I had to do that with another machine. What's confusing me is that it's not happening all the time, maybe 80% of the time; enough to have me concerned.
Ruth
Mechanic's stethoscope
Fred in NC
>So you can listen and find out where the noise is coming from.
Re: Mechanic's stethoscope
Phil Joines Krum, Texas
>A stick can be used to do the same thing. Just hold it against the side of you're head and place the other end on various place on the motor and headstock.
Tony - Memphis
>I had one too. Mine was a piece of the belt. It had frayed a bit and I had one string that was a one per rev clicking sound. Seems like I have had to tighten my wheel before too.
Tony
Keith Tompkins
Keith Tompkins
>HI Ruth, could be a set-screw has come loose also....
Carole in VA
>Ruth, I know this sounds simple and you probably have already done it, but be sure the belts are seated properly in their little grooves. If they are not, it will make a little ticking sound. At least mine did.
