Steel Wool
Steel Wool
Steel Wool
Rob Overton,Houston, Texas
>Just finished turning a walnut bowl. finished sanding with steel wool. Noticed that the bowl had lots of steel wool "fibers" stuck in the wood. What am I doing wrong? Is this to be expected? How can I be sure I have removed them all, or is this not a problem? Perhaps I am borrowing trouble...... :-0
Rob
Re: Steel Wool
Re: Steel Wool
>If it's an open pore wood like ash, oak or mahagony you can get steel wool stuck in the pores. It's really hard to get out. I only use steel wool on pieces that have lots of finish on them. Even then most of the time I use sandpaper. I save the steel wool for polishing metal.
Re: Steel Wool
Re: Steel Wool
Earl Eyre
>One of my favorite finishes and used on almost every piece is steel wool and wax. It almost makes a spit shined finish and takes out all the dust and imperfections. But John is right. You have to have a lot of finish on it first or the fibers will work into the pores. I have no problem even on Oak if I first put at least three coats of finish on the turning. I use the steel wool and wax just to do the final rub down--much like pumice and oil on furniture but it's not a substitute for a smooth varinish, shellac, whatever finish.
Earl
Re: Steel Wool
Re: Steel Wool
>Thanks for the information. Rob
