The good idea machine was working today
Mike Schwing from Md.
>Don't ya LOVE IT when you come up with an idea and it actually works! Especially when it is one that saves you time, time, time and makes your job a whole lot easier?
Granted, this might not be the "purist" way to accomplish this task, but it dawned on me today, in the middle of nowhere, that I could use my drill chuck in my lathe and conjure up a way to hold a 4" Kutzall carbide angle grinder disc. I already use a pneumatic sanding drum that way, why not a grinder disc? So I took the one on my angle grinder off and went to Home Depot, where I found just the right 5/8" hardware for it. Figured I could just hold it in the drill chuck and use the tapered mortise to hold it in. Then I discovered that the drill chuck I have is only good for 1/2" bits. Nuts! No problem, what about my chuck? Hmmm.. don't ya know the little pin chuck jaws I never use work just perfectly! Yippee dippee!
It works just great. Absolutely wonderfully in fact. Much easier to control than I had been concerned about. This literally saves me 60% of my carving/shaping work and the ladle you see in the photo was rough shaped from a bandsawn blank in under 30 minutes. Would have easily taken me 3 hours with my Foredom.
Anyway - hope this can help some of you, too. If not the Kutzall, in some other fashion. The lathe is good for all sorts of things. (I know this was not an original idea but it was for me)
Re: The good idea machine was working today
>Mike That looks like fun. I use a 3" angle grinder for most work like that. I would have to clamp the handle in something. For small work I like your idea.
JamieDonaldson
>But I get shivers just thinking about having my hands close to that wood eating monster! Be careful!
>Exactly what I was thinking. I use a coarse drum sander on my drill press at about 3000 rpm for rough shaping treen similar to Mike's, but not as elegant. Every so often, I break a nail and the hair on the back of my neck stands up, when I run a finger into the sanding drum. It would be a lot worse if I acidentally put my hand into the teeth of that carnivore.
While the idea of faster material removal without loss of control sure is tempting, I think I'll stick with holding the cutter with both hands, behind a guard, and clamping the carvings to the bench.
Eduardo Sarmiento Hall,lima peru
>Well that is really cool ,remindme of a video in glass carving in italy how they do it is a very similar case and have been thinking of carving my turnings that way and will try that and let you know the results
You guys are getting soft
>This is not a dangerous activity. Believe me, I'm Joe Danger. I intentionally put my palm on that spinning cutter and all that happens is that it throws it right out the back. There is no opportunity for your hand to become stuck on or dragged around and around as there is with a small burr to wrap itself up in your palm. Even if you contact it on top it just carries your hand down and throws it out immediately. The danger would come from continuing to hold it there as might happen with a hand held grinder.
William, how are you breaking a nail on a drum sander? The only way I can think of is that if it is rotating towards you?
Is this the end of the Turned/Not Turned Thread?
Randy Miller
>Since you are now using the lathe to shape your pieces ;-)
Re: You guys are getting soft
Pascal Oudet
>soft I don't know. cautious maybe.
your method is very similar to the way some olive bowls are carved in low cost factories: someone holds the bowl blank in his hands, and carves the inside out by pushing it against a rotating cutter mounted just like you. the only difference is that the cutter is a bit closer to spindle moulder cutters than to your Kutzall disk. (well, THAT might be a big difference in the surgeon's job)
take care.
Pascal
Engarde? Touche? ;~)
Jay in TX
Steven Antonucci
I've done this with a wire wheel
steve antonucci
>I turned a wooden "extender" (about 4") with a small 5/8" nub to center the wire wheel. I drilled a hole with my tailstock, and lag bolted/washered the wheel in place. Works great for texturing the outside of a bowl or hollowform.
Here a picture:
Steve
Now wondering if I should do this with my King Arthur chainsaw cutter... NOT!
Re: What a relief Steve,....
JamieDonaldson
>..I thought you were going to show mangled flesh!!!
Re: I've done this with a wire wheel
>Steve I chuck my wire wheel up in a jacobs chuck with #2 morse taper.
Steven Antonucci
Mine was leftover from an angle grinder
steve antonucci
>As you can see from the picture, it's a pretty big wheel, and it was torquey (not a word, but you get the idea). By putting the big spinny thing on 800# of steel, and concrete, I got control back.
Now, all I have to do it watch my fingers. FWIW- I also like the variable speed feature- since I can adjust the speed and pressure on the lathe to cut more/less agressively.
Finally, since it's just a 5/8" hole, I didn't have any way to grip it in a jacobs chuck. I originally made this arbor to hold my buffing wheel, but never really figured out the whole buffing thing... loosen the screw, change the wheel, done.
Steve
Re: Mine was leftover from an angle grinder
>Steve I like it. I have several more wire wheels but never thought of putting them in my chuck like you did. That may also be a good idea for a hard felt buffing wheel to polish the edge on my carving tools. I've been looking for a motor to permanantly mount that wheel but I already have a 750lb motor sitting right in front of me.
Hanger bolt and nut
Phil Joines Krum, Texas
>For changing wheels a lag would tend to strip the hole over time. A large hanger bolt and nut wouldn't.
David Barnett - Venice, Florida
>As Mike says, these aren't nearly so dangerous as they look. There are enough spikes near enough together that they can't take much of a bite, more akin to being nibbled by piranha than one-gulp shark kibble. The only time I've really been unpleasantly surprised was when I forgot to switch my reversible Foredom tool to 'forward' and the Kutzall 'Wood Blaster' took a lunge toward Mr. Mushroom.
Sean Troy
>Hey Steve, do you get any discoloration with the wire brush?
Steven Antonucci
none yet- cherry and poplar, so far
steve antonucci
Steven Antonucci
6 years, no problems yet
steve antonucci
>two reasons I can attest to this:
1.) If you look at the picture, the lag bolt is probably 2" long. That's a lot of threads to foul if your not a ham fisted idiot (I have little tiny girly hands...) Wasn't my original idea, but hey I got lucky.
2.) I don't have that many wheels. If I did, and I used them all of the time, I'd probably just make another one.
The nice thing is that they are easy to make, recenter automatically, and I made it out of a scrap. Honestly, I probably just used a ratchet to "tap" the threads with my lag bolt. If it takes more that 10 minutes to make, you're probably trying too hard.
Steve
Scott Hogsten
>Do you have a drawbar on that chuck ? If not add one - nothing like a loose drill chuck bouncing around your shop.
Scott
Re: none yet- cherry and poplar, so far
>I've wire brushed all sorts of woods and haven't had any discoloration. it is a really fun texturing tool.
>Scott When the chuck comes loose it just stops. I've used one this way for years and keep telling myself I should add a draw bar but each time it happens I just stop the lathe and jam it back in and do it again. Not saying it couldn't fly across the room but I've never had it happen.
>I'll believe you when you say it's not as dangerous as it looks. It's probably not any worse than my drum sander, and I like the geometry of the Kutzall a lot better. It looks like it would work a lot quicker at hollowing spoon and ladle bowls than my carving gouge and mallet, but not get in the way of the art.
My drum is mounted vertically in my DP, so one hand is usually on the upstream side and the other is on the downstream side. It's usually the downstream (left) hand that encounters the surface of the drum, and a chunk gets taken out of the end of a nail. I suppose the Kutzall would do the same.
You do set up a duct for dc behind it right?
MP Wall
>Mike, I hope you set up a dc chute behind the wheel to catch some of the dust that thing makes, other wise I wouldn't want to clean you shop. :-> MP Wall
RonZ
>You're just looking for an excuse to say it was done on a lathe. =o)
