Vacuum Pump Question
Dave_Wimmer
>I'm told vacuum chucking requires 20-25in of vacuum and 3-5 CFM.
Is it safe to assume the 3-5 CFM is a "no load" figure?
Dave_Wimmer
Re: Vacuum Pump Question
>YES.
The rating is for the capacity of the pump at "full flow." The more CFM, the better the pump can handle leaks in the system and seal as well as porosity in the wood. Some turners use a shop-vac as a pump. They will only get 5-7" of vacuum, but with 50+ CFM it holds pretty well (especially where voids and spalt are present) on some pieces. Note, too, that 25" may be too much for many situations. Pulling 20" of vacuum on an 8" diameter chuck will put more than 500 lbs of pressure on your piece and may be more than enough to implode it.
Your system should have a vacuum guage and a bleeder valve to allow you to tailor the amount of vacuum to the piece you're doing. For instance, I've held 18+" platters on an 8" drum chuck with only 10" of vacuum and had no problem finishing the bases and feet.
M
Jim Pugh, Ohio
>As a follow on to Mark's reply, when working with your vacuum system 10 to 15" of vacuum (by gage) is more than adequate for most things and may be too much for larger/thinner items. You will develop a feel for what is necessary. On the other hand, if the piece is leaky you may be real lucky to get 5" of vacuum and sometimes even less. You can still use the system but just have to leave the tail center in place until the very last few cuts. Also, you will need to develop a real light touch with your tools. Hey, if I can do it, anyone can.
Thanks for the info!
Dave_Wimmer
