Resin casting question
CapeMayMike
>Those of you that are casting resin for cabochons, pens, etc. I have a few questions.
Have you used epoxy resin and polyester resin? If yes, any significant differences between the two and is one easier to work with?
Do you use some sort of release wax in your molds?
Thanks!
Re: Resin casting question
>Mike I used a product called Cast-n-craft. I wasn't turning pens but it would work for that. I'll be interested to see what people are using to cast the pens that we've seen on WC.
Re: Resin casting question *LINK*
Ron in Drums PA
>I use polyester resins for cabachons and use small paper cups for molds. I make them about 1-1/2" tall and slice off what I need, when I need them.
Most pens makers also use polyester resins
Casting_Polyester_Resin
CapeMayMike
>Thanks guys. Polyester is certainly cheaper than epoxy resin, however I have over 1 gallon remaining from a boat restoration that I did so will try that. I'll be sure to take a look at that link.
What do you guys use as a coloring agent? I suppose just about anything will work. I have some ground colored powders from Michael's that I'm going to try.
Epoxy will bubble due to heat generated.
Dave Smith, Longview, WA
>Hi Mike,
Epoxy is not a good casting material because of the exothermic reaction of the two ingredients. Putting the casting mold into a vacuum chamber will help remove the bubbles from the casting but be sure there is enough room for the foaming that will result.
The mixture also needs to be tinted or colored unless you want an amber colored casting. I use cheap acrylic paint for that. I mostly use blank colored epoxy to fill voids in roughed out turnings.
The AAW Spring issue has an excellent article on casting epoxy with wood for making a goblet. The article will answer a lot of your questions and perhaps give you a couple of ideas as well.
Good luck.
Dave Smith
I have made a few epoxy pumice castings in Longview, WA.
Re: Epoxy will bubble due to heat generated.
>Dave I used to make artificial rocks for our rock climbing wall out of epoxy and sand. Worked great. I would make the form from sand and then cast it in sand. This gave the texture of sandstone so it felt like real rock.
CapeMayMike
>Thanks Dave. I know that this epoxy really cooks, so obviously you're right and I hadn't thought about bubbles, etc. I think I'll save this for future boat projects (I'm sure there'll be some) and buy some polyester.
