respirator
respirator
respirator
Mike Bourque
>Anyone own and use a Triton Respirator? Craft Supplies is offering it as this month's special but I have not tried one. Does the feed hose hinder movement. Any comments would be appreciated.
Re: respirator
Re: respirator
Craig Chambers
>Mike,
I recently purchased one from Craft Supplies. Here are my first impressions after one four hour turning and finishing session.
The helmet fit well and was easy to put on and take off. The face shield easily locked in both the up and down positions. There was slight distortion in the curvature of the shield. Not enough to affect anything but you could see it. For me, the ear pieces are not useful. Luckily you can lock them away from your ears. You can't remove them, as the shroud needs them to contain the air flow. The helmet assembly doesn't feel heavy and was quite comfortable. My contrast with this is my 3M Power Visor which is heavy. The neck shroud was OK. You have to tighen it around your neck to seal the bottom of it. Someone asked me about fitting it over a beard. I think it would fit fine.
The canister took some getting used to. It was a little heavier than I thought it would be and I kept having to tighten the belt. The air hose was fine and didn't get in my way. I would have liked a little more airflow but looking back, my glasses didn't fog up and my face didn't sweat so I guess it was adequate. The blower was quiet and the battery showed no signs of reduced power after four hours.
My main reason for buying the thing was a respiratory reaction I had a couple of weeks ago while turning and sanding a piece of wood. Nothing real serious but it was a wake up call for me. I have been told that wood reactions tend to be cumulative so I don't want it to get any worse. Same wood, no reaction after using the Triton. So I guess you can say it did what it was supposed to.
Regards,
Craig Chambers
Re: respirator
Re: respirator
Mike Brazeau
>I have had the Triton for almost two years and my comments are pretty much the same as Craig's. The new hose design does not limit movement at all. While turning this summer in my garage and humid, hot conditions I found the air flow somewhat low, but was still able to use it. I figure it is excellent value. I often use it even if going to do a short stint on the bandsaw or table saw with dusty wood.
Mike
Re: respirator
Re: respirator
Bruce in Saint John, N.B. Canada
>Mike see if you can get your hands on the fall 2004 issue of Woodturning Design magazine, there is an excellent product review on page 42 of the Triton Respirator. I agree with all of Craig and Mikes comments. I have had one and have been using it for 10 months, no complaints on this end. If you happen to get one make sure it has the new updated hose and connections. The first models had a stiff hose and they tell me it interfered with head movement but such is not the case with the new style hose and connections. The original models are no doubt depleated by now but one never can tell there may still be a few on suppliers shelves. Yes there is a small amount of distortion at the corners of the face shield but certainly not objectional. Try one I'm sure you will love it.
Re: respirator
Re: respirator
Bruce Wiseman
>I have one and agree with everything said. A friend had a piece of wood come off a lathe and hit him in the head, so the hard hat is a diffenate bonus.
