Wish me Luck...
Wish me Luck...
Wish me Luck...
Devon Palmer
>Ok,
Tomorrow I leave Columbus OH, headed to DC to pick up a HUGE domestic Cherry log spotted by an arborist friend of mine. Forest grown, 22" dia at chest height, 30 foot before the first branch. We have to fell it, I'm going to cut it into bowl sections as long as it is wide, and anchorseal the livin' cr*p out of it.
Other than hauling it safely, any other advise on cutting and preserving this guy for the 425 mile trip home?
- Devo
Re: Wish me Luck...
Re: Wish me Luck...
Gary Evans Tallassee, TN
>Good Luck, Devon!
The only change I would make in your plans would be to cut the sections 6" or so longer than they are wide. Even with the anchorseal you could get some cracking with cherry, especially if you are hauling it in an open truck or trailer.
Plus, with as much wood as it sounds like you will be bringing home, it may be a long while before you turn it all into bowls. The longer you keep it in the form of blanks, the more cracking you'll have to deal with. You don't want to have to sacrifice the width because of a few end checks.
Gary
Re: Wish me Luck...
Another addition
Jay in TX
>WOW, a log like that would be highly welcome down here in Fort Worth. But since its destination is too far north of here to worry about such things, I'll add this...
When you anchorseal the crap out of it, do so immediately after you make each cut. This will help prevent some of the rapid moisture loss that gives us those nifty end-checks that we love (not).
Further... and since you're planning on making them all bowl blanks; cut the pith out while you're at it to further reduce your blank's checking/cracking potential.
Good LUCK!
Re: Wish me Luck...
Re: Wish me Luck...
Bernie
>Do you plan on cutting the crotch or getting it.
I would be interested in it if so
I am in NE Ohio
Bernie
Re: Wish me Luck...
Steven Antonucci
Stand up the sections on end.
steve antonucci
>Lay down some Pressure treated Lumber, and stand the sections up on end (off of the ground, or you'll get bugs.) Gravity supposedly helps dry the lumber more evenly this way.
Steve
P.S. no hard data to back this up, but logs I've got upright have less cracking than the laying flat ones.
Re: Wish me Luck...
Re: Wish me Luck...
>That's an awful lot of bowl blanks! How about "planking" some of it? That would give you a few board feet of lumber. You could turn some into legs, tabletops, etc.
Re: Wish me Luck...
Keith Tompkins
Re: Wish me Luck...
Keith Tompkins
>Sounds like fun, Devon. 22" isn't all that large for a cherry....I cut up one that made 3 20" bowls from one section!
Re: Wish me Luck...
Re: Wish me Luck...
Ed Karch in No.VA
>Let me know if you need help loading. My truck has a lift that can hoist up, to 500lb. DC is a half hour down the road.
Re: Wish me Luck...
Agreed Steve, stand them up on end *LINK*
Jay in TX
>Steve,
No scientific data here either. But experience says this helps, as I stated in this previous thread (linked below).
Options for initial wood prep
Re: Wish me Luck...
Re: Wish me Luck...
Doug Trembath
>Devon, combine some of the other good advice you received here, and leave the log sections as long as you can, for a couple of reasons. One, you can keep a log a lot longer than you can blanks. Two, you can use it up at your own speed and temperament, instead of rushing to get it all roughed out. Three, you may well find a lot of uses for longer pieces, especially after geting bored with so many bowl blanks.
If you have a trailer, you can use a come-along and some rollers to winch them up into the trailer. Your end result will be much better success.
I also learned a trick a long time ago about transporting wood long distance. Cover the wood well with tarping or plastic to keep it out of the wind if you're using an open truck bed or trailer. Wind will whip the moisture out very quickly, especially in a dry area. Try to keep the tarping well down on the wood. Lots of small pieces of wood on top will help keep the covering from billowing, along with lots of tie-downs. Best of luck, and what the hey, stop by here on the way back!
Doug Trembath
Studio in the Woods
