Grain Filling On The Lathe
Dave Winters, Steamboat Springs, CO
>What's a good material and technique for filling the grain on the lathe, small items with open grain woods like walnut and padauk?
Thanks in advance!
Re: Grain Filling On The Lathe
woodspinner/ Bill Hale
>Hi Dave
It depends on the finish you want to use. If I am doing oil I just sand the final,220, and up with the oil and it closes the grain.
I generaly do not close grain on gloss finishes because I feel it is a part of the woods natural look.
Good turning and be safe
Bill in Casa Grande, AZ.
>I don't do much filling of grain unless I just put on lot's of lacquer but that takes a lot of coats. I do fill the grain with contrasting colors using shoe polish wax. Seal it with shellac after you do and then continue with your finishing. I have also used powdered wood glue. I mix it with water based analine dye so it's the color I want and thick enough to fill in the pores. Then I sand it off when it's dry. This would probably work for a pore filler if you color it like the wood.
