Veritas - Innovation in Tools
Beginning Bowl Turning Question
Kim Martin
>Hello all, I have been turning pens for a couple of months, and am thinking about trying my hand at a bowl. I am wondering what tools are a must have for turning bowls. What I have right now are a couple of spindle gouges, a parting tool, and a skew chisel.
Thanks in advance for your advice!
Kim
Re: Beginning Bowl Turning Question
>How big a lathe? If you have a "big" lathe (1 HP or greater) - a couple of bowl gouges are in order (small, medium and maybe large). If you have a "small" lathe (1/2 HP), I'd stick with a small bowl gouge.
Scrapers are nice (particularily if you aren't as talented as some with the gouge). A thick radius scraper (3/8" thick) and maybe one or two others. Of course we are talking some moderately serious money. So pick out a bowl gouge and a scraper to start.
JamieDonaldson
>The closest thing to a universal bowl turning tool is a 3/8" deep flute side ground bowl gouge. Everything else is a suppliment to this, depending on lathe size, bowl size,etc.
JKJ in East TN
>I think you can do most bowl work with a relatively large bowl gouge (sharpened with the wings swept back) and a scraper that is curved on the left side. I like the 1/2" deep gouge better than the smaller sizes except for small bowls or occasional detail. The gouge is used on the outside and inside; the scraper on the inside. The gouge can also be used as a shear scraper on the outside of the bowl.
A flat scraper (1") is also nice, or two - one angled each direction, but not as important as the other. In a pinch, you can use a skew chisel on it's side as a scraper to get into tight areas such as next to the foot.
Another thing - if turning dry wood I like to have two bowl gouges with identical grinds. With dry wood, the gouge can get very hot. With two, just switch to the other and keep going. (You get twice as long between sharpenings as well!)
Jill
>I bought a David Ellsworth bowl gouge....sweet!!!!!!!!!!!!! I turned my first bowl without too much difficulty. The only thing I found is I couldn't turn very tiny bowls which I like to do. However, if you are starting out with a bowl around 4 inches in diameter the Ellsworth could be a nice choice.
Jim Pugh, Ohio
>Well, you asked a beginning bowl turners question but you didn't get any beginning type answers... So, get the book "Woodturning - A Foundation Course", second edition by Keith Rowley. Woodcraft is selling them at the moment for $14.95.
Next, find a woodturner who can show you how he/she turns a bowl and what tools he uses. The swept back bowl gouge that most recommend requires a jig to sharpen properly and some instructions on how to do so. Don't be shy about learning to turn bowls, just do your research before spending a bunch of money.
Enroll in a Class...
Wally Dickerman in Arizona
>The best advice that I can give you is to enroll in a class on bowl turning. Your instructor can give you good advice on the tools you'll need, and you'll learn how to use them. Among other places, Woodcraft stores regularly give turning classes.
Wally
