Finish question for cocobolo
Tony in VA
>A friend of mine wants me to turn a small dish (approx 5" in diameter) to put on the bathroom counter for her husband to put his watch and whatever in when showering. What finish would you use on cocobolo in this environment? Is the natural oiliness (sp?) of cocobolo enough or maybe teak oil or...? Thanks for the help.
Tony in VA.
Re: Finish question for cocobolo
>I was asked to do the same thing this weekend except she want's it out of locust. I think I'm going to try a modification of a bowl I made years ago. I used West System Mirror Coat. It is a 2 part epoxy you can get from Woodcraft. I used it on the bowl the way it is supposed to be used on a counter top except I put it on very thin. I still didn't like the finish because it looks plastic. I think I'm going to try to either thin it or apply it and wipe it off to see if I can get a thin layer that will still protect the wood. This lady wanted to use it for a soap dish so it will have water setting in it until it evaporates. I think it will almost have to be an epoxy finish to withstand this.
Carole in VA
>I am getting ready to make a similar item for a dresser. I think I am going to use something that is is easily renewable like an oil/wax blend. Any hard finish is probably going to get scratched by the watch, change, etc. Briwax makes a creamed beeswax that might work. Actually, it is a blend of beeswax, linseed oil and turp I think. Don't have the can in here to read the ingredients. I use it on tool handles.
JKJ in East TN
>Things I've made from cocobolo seem impervious to water. (Under a microscope the pores are filled with resin so I don't think it can soak up too much water!)
I mostly make small things and use friction polish or wax. I made some cocobolo boxes finished with Mylands friction polish and the owner's said they've held up fine although I don't think they are kept in a steam room.
BTW, the first things I made from cocobolo I finished with the same oil and wax I used on everything else - I don't know if it's related but they have turned very dark after a few years. Some other things I finished with friction polish (shellac) have retained their golden orange/brown colors.
dick mcneill
>It's been my experience that Linseed oil will turn coco bolo a very dark color & will visually obliterate all grain pattern.
