A55 Smoothing Plane
anyone use the Tru-Grind jig (by Woodcut)?
Carles, in Barcelona
>I have the Sorby fingernail sharpening jig, but not very happy with it.
Nobody sells the wolverine jig here in Spain and I can buy the Woodcut Tru-Gind jig in the Woodcut-Tools website. 110 euros ($132) with shipping.
I can't try the jig before buying, so your opinions are welcome.
Un saludo
Carles.
Re: anyone use the Tru-Grind jig (by Woodcut)?
Kelton System
David Propst
>Based on Lyn Mangiameli's Sharpening Systems Overview, if I were buying a sharpening jig system today I would buy the Kelton system for all the reasons he mentions. It has advantages over both the wolverine and Tru-Grind systems. I think Lee Valley carries it.
Best regards,
David
Re: Kelton System
>David,
Many thanks. I'm going to read this article.
Un saludo,
Carles.
They all do the same thing
tdaniel
>Carlos, keep what you have. The Sorby is the same jig that comes with the Tormek grinder and it will do a fine job with your gouges. With any gouge jig you must remember that they only give you angles....not profiles. They all require hand/eye coordination which means you must know what you want before going to the grinder. These jigs are only an aid to sharpening and will not guarantee you the profile you want.
TD
Re: They all do the same thing
Lan Brady
>Carles,
I use the Tru-Grind system. I am very happy with the repeatability on all my tools, not just the bowl gouge. The jig has a scale of 1-4 and the slide has a scale of 1-25. I write the set up for each tool on the ferrel and I can repeat the set-up very quickly for any of the gouges, skews and/or scrapers that I use.
Good Luck with your decision, Lan
