segmented bowl pic
Kevin Turner
>trying, to practise with some patterns. Q does the pattern usually change appearance ( inside) referring to the large bowls that look like vases , with the narrow opening?
segmented bowl pic
Kevin Turner
Re: segmented bowl pic
Russ Fairfield
>If you want the patterns inside and outside to have the same size and perspective, there are 2 choices.
When using a tapered pattern in the segments, the pattern on the inside will be different from that on the outside because of the taper, unless you turn to a very thin wall thickness to minimize the effect of the taper.
Or, you can make the pattern pieces as straight sections, and then make up the taper between them with the filler pieces in between them. These filler pieces can be either plain or have a pattern that doesn't change with their taper.
Or, I don't understand your question.
Kevin Turner
>Russ, I think I understand the answer. Just wondering if I'm on the right track.. Thanks. KevinT in Thunder Bay
