REAL MILK PAINT
Chuck help
Chuck help
Chuck help
Tony Augruso
>I have the 26020 20" general lathe and I'm now looking to add a chuck to this lathe. I've been looking at the oneway chucks. Is there any reason not to purchase their largest chuck, the stronghold? Is the talon good enough?
Is there another chuck that I should consider?
Thanks,
Tony
Re: Chuck help
Re: Chuck help
Ed Karch
>If you are looking to do big stuff on that 20" go for the big chuck.
Re: Chuck help
Re: Chuck help
>Tony I would go for the big chuck even though I've turned 19" bowls with my vicmarc 100 which is about the same size as the talon. I'm probably pushing my luck.
Re: Chuck help
Russ.....
W.C. Turner
>has a good article on buying chucks. Look at the menu on the left of main page.
W.C.
Re: Chuck help
Re: Chuck help
>The Oneway Stronghold should do you quite nicely. The Vicmarc is also good. The Oneway Talon would be good for smaller projects.
Re: Chuck help
Re: Chuck help
JKJ in East TN
>Try a search for previous threads on this. Here are a couple I found:
http://www.woodcentral.com/cgi-bin/turning.pl?frames;read=74534
http://www.woodcentral.com/cgi-bin/turning.pl?frames;read=78527
Re: Chuck help
Thanks, Everyone
Tony Augruso
