Miniature Hollowing Tools
Jennifer@Indy.USA
>For Scott and Carole...or whoever else cares...here are couple of pictures of the two tools that I use to hollow most of the miniatures that I make. One is made from square bar stock and has a HSS tip silver soldered (rather crudly I might add) to it, the other is just an allen wrench bent and ground and glued into a little handle.
No rocket science involed :)
I find it easiest to sharpen these on a belt sander by holding them at the correct angle to get a fresh edge. I like to hold them on the belt in that soft spot just behind the guide roller when doing this.
Hope this might add to your arsenal of tools :)
Jennifer
Re: Miniature Hollowing Tools
Carole in VA
>Thanks, Jen. I have heard a number of times about using an allen wrench as a tool. Can you use just any allen wrench? Some of them seem so cheap and soft now days, I wonder.
Re: Miniature Hollowing Tools *LINK*
>Those look like fun.
There is an excellent article on making your own Hollowing tools I don't see any reason why you couldn't miniaturize them.
Carole I would suggest that you could use any allen key. The difference will be in sharpening and maintaining a sharp edge.
Make your own Hollowing Tools
JamieDonaldson
>Other options for tiny tools are concrete nails and old screwdrivers. The quality of the metal is not the best, but the price allows much regrinding and frequent replacement as needed.
Scott Greaves, Blackfoot Idaho
>Thanks Jennifer!
It really helps just to see them. I have some hex keys I bought for this purpose, but I haven't done any work on them yet. I'm going to have to get to it!
BTW, I especially like the handle you made for the one tool!
Scott.
Lan Brady
>Jennifer,
I make my hollwoing tools from allen wrenches also. I buy the 25 pack on sale at HF for less than three dollars. They are the long handled.
I have found one trick that improves the cutting greatly. About half way down the neck, I bend the wrench backwards. The end result is that the cutting point is now in line with the shaft of the tool, but I still have the "c" shape so I can reach up under the the lip of the hollow form.
You can heat it with a propane torch and bend it with two pair of vise grips. It does not affect the temper near the point. because the heat is not near there.
I wish I had a camera to send you a picture, because it improves hollowing greatly.
Good Luck, Lan
Re: Lan, simple but great tip. Thanks.
Al Crandall- NE of Indy
