Bandsaw accessories
Gary Evans Tallassee, TN
>Hi all,
I picked up an older model 14" Delta bandsaw the other day. I am going to need new tires and I would like to add a new tensioning spring, a tensioning crank and a riser block.
I have the phone number for Iturra Designs and I found a place called R&D Bandsaws. I also looked at Highland Hardware. Any other sources that you could recommend?
I'm hoping I can find a riser block for less than $119. That seems a little high for a piece of steel tube and a couple of bolts.
Any other necessary accessory recommendations would also be appreciated. This saw will be used primarily to cut out turning blanks. Big surprise, huh?
Thanks,
Gary
