how to remove white water spots?
dick mcneill
>I'm doing a craft show this weekend & was subjected to a sudden downpour (related to Hurricane Rita) All of my turned items (pens, bowls, bottle stoppers & wooden clocks got wet & exhibited water water marks rendering them unsaleable. They were finished with friction polish (BLO, Shellac & DNA) or oiled and beall buffed. Any suggestions for a quick fix. I have two more days at the show so refinishing is not an immediate option. Thanks
Re: how to remove white water spots?
Earl Eyre
>If you have a quick access to some paste wax and 0000 steel wool, dip the steel wool in the paste wax and work it into the wood. Buff and your shine should come back minus the water spots. Keep the steel wool well saturated with the wax--it will not only get rid of the water spots but everybody will be picking up the pieces and loving the way they feel.
Earl
Russ Fairfield
>Rub some mayonaise (not salad dressing)on the wood. Then wipe it off and put on a coat of wax and hope nobody knows the difference.
Refinishing is the only cure that I know of for water spoys in shellac.
thank you
dick mcneill
>The suggestion about the paste wax & 4 ought worked well. I was going to use the mayonaise but used it on my tuna salad instead. I thank both of you for your answers. Sales went well at the show despite more rain.
