Friction polish question
Robert Savit
>I've been having some problem with a friction polish (Myland's). I think I know what the problem is, but I wanted some confirmation.
I've been using the polish on some small spindles, sanded to 600 grit. It seems to go on fine, and creates a nice glossy sheen, but a few days later, the finish degrades and is rough and dull. I checked the bottle and it is about a year out of date. I suspect this is the problem. Can anyone confirm this? (I bet Russ knows the answer.)
Thanks,
Bob Savit
Re: Friction polish question
Russ Fairfield
>If friction polishes are as easy to use as they are advertised, why do so many people have problems with them??
It could be old. No finish will last forever after the bottle has been opened, and some have a short life before it is opened. A good rule is that, if the the finish is dated, and it is past that date, throw it away. There is nothing to be gained by using old finishes.
Generally, a shellac friction polish stays soft when it gets old, and this can appear to be a dull gloss.
But it could also be a few other things. You said that you got a gloss, and that it disappeared after a few days. That would make me believe that the finish is still OK, but that oils in the wood could be a problem. These oils will migrate through the finish and make the gloss disappear. Olive is bad about this, and Walnut and Cherry can also be a problem. If this is the problem, let the finish set for a few days to allow it to cure and seal the wood. Then buff it with steel wool and do it again. You should be OK the 2nd time.
You could be introducing the oil into the wood if you had used Mineral Oil as a sanding lubricant. The effect is the same.
You could also be leaving oil or wax in the finish by not getting it hot enough to boil them out when the polish is being applied.
Robert Savit
>Russ,
Thanks very much for the comments. In fact, I've been using the polish on walnut, cherry and maple. I'll try your second coat idea and see what happens.
Bob Savit
