Color bleed question...
Tony - Memphis
>I've been playing around with making bottle stoppers. I ordered some from Ruth Niles (very nice stuff btw). just for kicks, I glued up 4 pen blanks - two maple and two paduak. The maple has a nice orange tint to it after sanding. I know this must be an issue with those segemented turnings a lot of folks do. Is there any tricks? One thing I tried was a thin coat of shellac before sanding, but I still got the orange tint. The effect is neat even with the tinting of the maple. Thanks for the help.
Tony
Re: Color bleed question...
Bill Stehman ... AZ
>Troy,
I use all the reds and blacks next to holly and have learned to use very sharp tools for the final cuts then start with 220 sand paper with high pressure air blowing on the piece at the same time. Then blow again and again.... then use a spray sealer. Never use a course sandpaper as it spreads the migration.
Hope this helps... works for me.
\Bill... AZ
>Tony First cut as cleanly as possible and then shear scrape. Then put some finish on to fill in the pores a little. Then sand. Blow the dust out of the pores and sand some more. Sometimes I apply some finish between each sanding grit. Clogs up your sandpaper but filling the pores with a little finish makes it easier to clean out the sawdust between each grit. By the way the only thing worse than padauk and maple is padauk and ash.
Thanks!
Tony - Memphis
