Tried and True Original
Carole in VA
>Is it supposed to be really thick in the can?
Carole in VA
Yes, very thick.
RevDoug
Thanks, Rev
Carole in VA
>Didn't know if I had old stuff or not.
Re: Tried and True Original
Rick Castrios
>I use a small crock pot on low setting to warm up the finish prior to applying. It goes on much easier when warm and allows you to use thin coats for faster drying.
Rick
AnthonyY
>I used it for the first time last week, I don't like as much as a oil finish. It seems that I have more latitude with oil mat, or gloss with the original I can only get a satin finish.
Carole in VA
>I wanted to try it because of it's environment/health friendly properties. I have put one coat on a small test piece and will try a couple more coats aand buffing to see what happens.
