My Procedure....
Wally Dickerman in Arizona
>I seldom have my tailstock on my bowl lathe. Only for very heavy or very deep pieces, or for large natural edge pieces.
I mount the blank on the lathe, usually using a screw chuck. I partially turn the lower part of the hollow form (I seldom turn bowls) I true up the area where I'll mount the glue block, including a final touch with a 1 inch wide, 80 grit sanding stick, and a pencil outline to center the glue block. I remove the blank, leaving it on the screw chuck. I glue on the glue block after making sure that the surface is true and flat, using med. CA glue, and accelerator. Use lots of glue and only hand pressure. Should be some squeeze-out. If the joint fails it's usually because not enough glue was used. I remount the blank and mark the center of the glue block with a pencil while the lathe is running. I then remove the blank, drill a 1/4 in. hole in the glue block and mount it on the lathe. To get it good and tight I use a 14-inch pair of slip joint pliers on the glue block. This is important for good solid cutting. (If you were using a faceplate and 4 or 6 screws, you'd tighten all of the screws). Now you're ready to go.
If the piece is quite deep, I don't use a glue block. If I do use one I'll cut a 1-inch x 1/4 inch deep tenon on the blank, and a corresponding opening on the glue block. Makes a stronger joint.
Yellow glue works as well as CA glue, but there's a drying time.
When I'm teaching classes, I show students the various ways of mounting a blank to the lathe, such as 4-jaw chucks, tape, etc. We then use a glue block and either a faceplte or a screw chuck. I just want them to know how to do it. Some continue with a glue block, others purchase a chuck. The point is, you don't need a chuck. I have 2 and seldom use them....my choice.
Wally
