About screw centers
About screw centers
About screw centers
W.C. Turner
>Hi,
I may have discovered why the screw ctr. twisted in my VM120. In Raffan's Turning Bowls book, he says the screw's that come with commercial chucks, are fine for small blanks up to 6".
The blank I tried my screw in was larger than 6", & probably didn't tighten enough, & I also made the mistake of not using the tail center for support.
Raffan also mentions that he uses(at least in this book)the Glaser screw chuck. I just can't justify $130 or more for a "screw". (no pun intended)
Thanks,
W.C
Re: About screw centers
Brad Vietje
Re: About screw centers *LINK*
Brad Vietje
>Hey W.C.,
Depends on the screw center, the chuck and the experience of the turner. I've only gone up to about 15" with a Oneway screw center, and a Supernova Woodworm Screw.
Screw centers, or screw chucks can be used for bowls up to 24" or so, but only with great care and experience. The "Bowl Mill" in central VT has been coring logs, and making bowls for a very long time (since 1857), and it's amazing to see how little holds these chunks of wood on the lathe.
Check out the web site below, especially the links to the process and the mill at lower right -- don't try this at home !
Safe spinning,
Brad Vietje
Thetford, VT
Granville Bowl Mill
Carole in VA
>I guess I am gonna have to try mine soon. Everyone says they are safe and hold great, but I just have never found a specific need for it. I am also more comfortable with between centers and it just seems quicker. I don't have any problem turning the tenon when I have the piece between centers.
Jennifer@Indy.USA
>Carole I thought the same until I had a blank fly off and head right for my face. Thankfully I was using a lathe that had one of those plexi shields and also a face shield. It was up at Sophie's BB-Q and I tell you since then I have never turned a tennon on a bowl blank between centers. Since I started using my woodworm screw that came with my Oneway Stronghold chuck I hardly ever use a faceplate and never between centers. It is so easy and so much quicker than messing with a faceplate and all the screws. Granted I don't turn anything much bigger than 16" tops. I don't have the arms to lift anything much bigger than that!
Give it a try....I think you'll like it!
Jen
Wally Dickerman in Arizona
>Craft Supplies, Woodcraft, and others sell a very good screw chuck for $45. The Threads aren't quite as thin and sharp as Glasers, but they work well. I have a couple which I use for classes.
Properly used, a screw chuck will hold blanks well over 12 or 14 inches in dia.
Wally
Ruth Niles
>Jen, I'm not Carole but I've always felt the way she does and I'm going to give the screw chuck a try because you make it sound sensible. Guess a flying blank is a good reason to change one's process. : )
Ed Karch
>Just finished a 16" bowl that started out on a screw chuck. I use the tailstock until I am ready to reverse and chuck it up. Up chuck it?
Ed
Carole in VA
>Hmmm...that's something to think about! I guess when I get my new lathe next week (stealth gloat) and can turn larger pieces than on the Mini, I will try the screw chuck. I hate fooling with faceplates and I can see where a large blank (I only have a jet mini right now) between centers might be a little risky. Is there a limit to the size blank you should use a Woodworm with? Guess I should dig out my Supernova2 manual...it probably tells me. Heck, I don't even know what size drill bit to use with it! Ruth, let me know how you make out.
bernie feinerman
>I used a screw center (Sears - MT1) and tried to turn a not too round green piece of wood and had the screw strip out after a few "catches", i.e. got in too close with a gouge while roughing and had the wood stop spinning a few times too many.
I am going to try making a screw chuck with a 1/4" lag bolt - any suggestions on the making, care, and general treatment of screw chucks?
Bruce in Saint John N.B. Canada
>Lag bolts will work for screw chucks and I have used them but that was before I purchased Oneway Woodworm Screws. I think you will find the thread pitch is not the same and especially the thread depth. I think it would be safe to say that lag bolts don't offer as great of holding power as screw chucks. Perhaps you have read between the lines that I no longer use lag bolts, too me it is an accident looking for a place to happen. Hope this helps, good luck turning but do it safetly.
Bruce in Saint John, N.B.
Brad Vietje
Brad Vietje
>Bernie,
That may work, but the high-quality screw centers have very deep, thin threads that are nearly parallel. The screw merely pulls the wood against a flat surface (usually w/a raised ring at the edge), or the top surface of the chuck jaws. The better the mate between the wood and metal, and the larger the diameter of the supporting disk, the better the hold. The Glaser screw chuck holds very well because the threads bite the wood without pulling and prying it apart, due to the very thin, hardened threads. A lag bolt will be FAR inferior.
Safe Spinning,
Brad Vietje
Thetford, VT
If using a lag screws, I would use at least 5/16" or maybe 3/8" instead of 1/4 since it will probably not grip as well as deeply cut threads on a screw chuck. Also, grind the point and taper off since the blank will be pre-drilled with a clearance hole and the point will add nothing except unuseful length.
Are you going to support the screw by threading it through a piece of wood mounted on a face plate? Or are you going to hold it in a chuck or machine something to hold it? If you buy a long lag screw, you can get on with an extended length of unthreaded shaft near the head for mounting.
Shop around for lag screws. I find the quality and finish varies widely. Some are horribly made.
JKJ in East TN.
>>...Glaser screw chuck. I just can't justify $130...
I have used screw chucks with larger pieces, but like others, support unbalanced pieces with the tail stock as long as possible. Did you try grinding flats on the screw base for the chuck to grip? (Best if they were even to keep the screw centered to allow remounting if necesary.)
BTW, I mailed a Supernova screw for you to try.
JKJ in East TN
Do I like screw chucks, or what?
Hawaii Turner
>Seeing this thread, I just had to take a pic of my screw chuck collection including the 3 woodworm screws that came with my Vicmarc chucks.
I tried one of those, and when it didn't hold tight enough to suit my agressive turning style, I designed and made each to suit a particular need at the time. Most use a 3/4" hole.
Aloha, Doug
Re: Do I like screw chucks, or what?
>Wow, where do you buy stock with threads like that, or do you cut it yourself on a metal working lathe?
JKJ in East TN
tek-Brunswick, Ohio
>Bernie,
I am familiar with the Sears #1 Morse screw chuck. That is a very small screw chuck and is not intended for any work over 3” in diameter. I used to have one. The larger screw chucks are much larger both in length and diameter. The good ones also have deep sharp threads. Don’t Judge the other screw chucks by your results with the small one.
Tom
Jorge Castaneda
>Carole,
I use the screw too, is easy, I suggest learn to use it with your small lathe before going to bigger stuff.
The drill bit size is a shade smaller than the center part of the screw, put your caliper between 2 threads, and dill also a shade lees than the lenght of the screw unless it is extremely hard wood, then drill the diameter as read from the caliper and as deep as the screw.
mis dos centavos
Jorge
Hawaii Turner
>Aloha John,
Yes,I cut my own threads on my metal lathe.
Doug
