Between Centers
Between Centers
Between Centers
W.C. Turner
>Hi,
I have begun to start bowls between centers, to prepare them for a chuck.
Up to this point, I have not been able to see any advantage, for being able to move the blank around. I've heard folks speak of this, but, have never seen it done.
If you have it centered when you begin, then, if you move it around, it will no longer be centered, to cause vibration.
So, can somebody explain the advantages of being able to move a blank around in between centers?
Thanks,
W.C.
Re: Between Centers
Re: Between Centers
Sean Troy
>Why would you move it around? I just turn the bowl, put a foot on it and it is ready for the chuck. Maybe I missed what you were asking. Sean
Re: Between Centers
Re: Between Centers
Mark Wollschlager
>You might want to move the blank, after you have removed some of the outside.
You may have found a bark inclusion, crack, or knot that would be better off removed by changing the blank a bit and re-turning it round again.
You also might recenter the piece to get better grain orientation and then turn the tenon.
mark.
Re: Between Centers
Re: Between Centers
Sean Troy
>I knew I was missing somthing.
Re: Between Centers
Re: Between Centers
>WC I do it for several reasons. As was mentioned below sometimes you want to either get rid of or adjust the position of a significant feature in the wood. I also move the wood when I see the grain is going to be off center. I either want it centered or very off center but not off just a little. You are right in that if you move the wood very much it throws the bowl out of round and you have to true it up which makes it smaller. For this reason try to make your decicions early.
You don't have to move it at all. There's nothing wrong with just turning the bowl, BUT, what if you want to. If you've used a screw center or screwed it on a faceplate you can't, or at least it's more difficult.
I adjust the wood all the time when doing a natural edge bowl. I like the sides to be the same height and sometimes just moving the center 1/8" will noticeably change the height of one lip or the other.
Re: Between Centers
Brad Vietje
Re: Between Centers -- longish
Brad Vietje
>W.C.,
I am one of the guilty parties who suggested starting every bowl between centers, whenever possible -- at least, that's what I do. I often move one end or the other to give the piece the best balance and to show off the figure best. Yes, indeed, that means removing a little more material to true up the bowl, but I'm almost always going for quality of bowl, not quantity of bowl.
As mentioned, there are sometimes hidden flaws that can be removed from an otherwise usable blank (or should that be otherwise un-usable?). This can be a safety factor, as in a crack or inclusion, and an additional safety factor is that a blank held SECURELY between centers isn't as likely to fly as many other mountinng methods, though the blank still has to be mounted with care.
All these aside, I think the biggest reason is the beauty of the end product, and I'm being a picky perfectionist here. The difference between a good bowl and a truly great bowl is usually attention to these little details that set one's work apart, like turning the bottom of the foot, or the inside of a lid. This is especially true of natural-edged bowls and vases. If the opposing edges are way off, it looks intentional; if they're just a little off, it looks sloppy and unprofessional.
In my mind, the difference between a $500.00 gallery bowl and a $75.00 craft show bowl is an accumulation of these small differences. I've seen (and made) a number of bowls that were nice enough, but "missed by that much". I am not offended to see high prices on truly excellent work, but feel really cheated and put out when someone puts the higher price on a piece that is really only so-so. This does a disservice to the entire turning community, just as putting $35.00 on a bowl that your professional turning friend is selling for $350.00. "Nuff ranting -- that's my 3 cents ...
Safe Spinning,
Brad Vietje
Thetford, VT
Re: Between Centers
Keith Tompkins
Keith Tompkins
>Not really a rant Brad. You are correct on all counts. BTW, if anyone is planning to attend the totally turning symposium, you will get to see Brad's excellent work in person.
Re: Between Centers
Between Centers
W.C. Turner
>I've been turning for a while, but, haven't turned as much as a lot of you. I still consider myself a beginner, & it seems as though I'll always be one.
When I started turning bowls I used a faceplate, recently tried the screw center, & I now, think since I tried it, I like the idea of starting the bowls between centers. I suppose it's just that I haven't turned enough bowls, & found the right stock to see the advantage of being able to adjust a blank.
Somehow, I always have more questions than answers?
Thanks,
W.C.
Re: Between Centers
Re: encouragement
Ned Bulken
>w.c.
can't speak to any of the above from experience, we haven't even set up our aged lathe. HOwever, don't beat yourself up over expanding your repertoire. you're learning and you're out there turning. I for one learned a bunch just from following this thread, I look forward to trying these approaches, from using a faceplate, to affording and using a 4 jaw chuck, to turning between centers when I progress to that level. as you progress in your skills, you will continue to refine your approach, and your pieces will become more polished.
Re: Between Centers
Re: encouragement
W.C. Turner
>Thanks, Ned, I need all the encouragement I can get!
W.C.
Re: Between Centers
Brad Vietje
Um, Well, probably not :(
Brad Vietje
>Thanks for the good word Keith,
Looks like I'll have to mail in a piece if anyone's going to see it. I'm trying to renovate an old house on a tiny thread (not even a shoestring !) and I can't afford a weekend away as I have no $$$ till my house sells, and there are only so many weekends till freeze-up. Looks like I won't be able to make it this year. Have a great time, and make sure Bill Grumbine has fun -- his first symposium, I hear !
Safe Spinning,
Brad Vietje
Thetford, VT
Re: Between Centers
Keith Tompkins
Re: Um, Well, probably not :(
Keith Tompkins
>Bummer Brad..If you mail me a few items, I'll put them in the instant gallery, and get them back safely to you....let me know!
